Find the magnitude and direction of a magnetic field(Biort-Savart Law)
The discussion revolves around calculating the magnetic field at point P due to a current-carrying arc using the Biot-Savart Law. The user initially calculated the magnetic field as 1.0472E-6 Tesla but incorrectly converted it to nano Tesla, resulting in an erroneous value. The correct conversion should reflect that 1 Tesla equals 10^9 nano Tesla, leading to a final answer of 1.0472 nT. The user also noted a discrepancy between the angle in the drawing and the problem statement, which could affect the calculation. Ultimately, the user realized their mistake in unit conversion and expressed gratitude for the clarification.
Raziel2701
A current path shaped as shown in the figure(I included the picture at the end of post) produces a magnetic field at P, the center of the arc. If the arc subtends an angle of θ = 60.0° and the radius of the arc is 0.400 m, what are the magnitude and direction of the field produced at P if the current is 4.00 A?
B=\frac{\mu_{0}I \theta}{4\pi\,a}
It's straight from the book. And I know it's relevance due to the shape I'm dealing with.
Doing that calculation I get an answer of 1.0472E-6 Tesla. The book wants the answer in nT, which I assume to be nano Tesla. I figure I need to move the decimal point three spaces. Giving me a result of .0010472 nano Tesla. The book, well, webassign is telling me this is wrong. I'll try to get the picture in here if I can get it to work.
What I substituted into the equation shown above is the following:
\mu_0=4\pi * 10^{-7}
I= 4A
\theta=\frac{\pi}{3}
a=0.4m
I noticed a discrepancy between the angle shown in the drawing and the one given in the problem, but I think it's a matter of webassign directly taking the drawing from the book and placing it here. The problem in the book does have an angle of 30 degrees, but webassign randomizes the given numbers. Meaning that I don't think the drawing's angle reflects my given numbers.
I don't see what I am doing wrong. The image of the problem is number two by the way.
What am I missing?
"Doing that calculation I get an answer of 1.0472E-6 Tesla.
result of .0010472 nano Tesla. "
If your high is 1.7 m and somebody wants it in cm-s, you would say that you are 0.017 cm high, as you needed to move the decimal point by two?
Your first result 1.0472E-6 T is correct. And 1 T=109 nT. Do you get a smaller or higher number if you give the result in smaller units?
ehild
How could I be so dense? It hit me like a train.
Thank you good madame/sir!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
