What Was the Original Mole Percentage of O2 and H2 in the Mixture?
The total pressure of a mixture of oxygen and hydrogen is 1.00 atm, with the remaining gas after ignition being pure hydrogen at 0.34 atm. The calculation shows that 0.66 atm corresponds to water produced, leading to a composition of 78% hydrogen and 22% oxygen in the original mixture. The method for verification involves reversing the calculation to ensure consistency with the initial conditions. The discussion emphasizes the importance of self-checking calculations in chemistry.
JeremyC
The total pressure of a mixture of oxygen and hydrogen is 1.00 atm. The mixture is ignited and the water produced is removed. The remaining gas is pure hydrogen and exerts a pressure of 0.34 atm when measured in the same volume and at the same temperature as the original mixture. What was the composition of the original mixture in mole percent?
2H2 +O2 ---> 2H2O
3. The Attempt at a Solution [/B]
1atm - 0.34atm = 0.66atm H2O
for every 1 mol of H2 that reacts, 2 mols of H2 react so,
0.44atm of the water is H2
0.22 atm of the water is O2
0.34atm +0.44atm = 0.78atm H2O
0.22atm O2
78% of the mixture is H2
22% of the mixture is O2
Can someone check this?
I think that is quite OK.
However for this sort of calculaction if you haven't got anyone to check it for you you can do it yourself. You just take your conclusions and pose the inverse question, suppose you have this initial composition (which is your answer) how much H2 would you get from it if you reacted it? - the answer should correspond to the first question.
Hello Jeremy, :welcome: (somewhat belated).
PF isn't really in the business of stamp-approving answers -- it would only create tension between PF and teachers in general -- especially in cases where opinions differ. Read the guidelines ...
However, in your case there is little room for doubt, uncertainty and fear. So I wonder why you ask at all ?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
