I Find the natural frequencies of small oscillations
To find the natural frequencies of small oscillations in the given system of differential equations derived from Lagrange equations, one must first express the equations in a standard linear form. By solving for the accelerations ##\ddot{\theta}## and ##\ddot{\phi}##, the system can be represented as ##\ddot{X} = -AX##, where ##A## is a matrix derived from the coefficients of the equations. The natural frequencies are determined by the eigenvalues of the matrix ##A##, which indicate the stability and oscillatory behavior of the system. The term "where the frequencies diverge" likely refers to identifying conditions under which the system becomes unstable, leading to unbounded oscillations. Understanding the relationship between the matrix and natural frequencies is crucial for analyzing the system's dynamics.
rakso
TL;DR Summary
Hi,
Given a mechanic-problem, I've linearised a system of two differential equations, which the origin was Lagrange-equations.
The system looks like this;
$$ 5r \ddot{\theta} + r \ddot{\phi} + 4g \theta = 0´ \\ 3r \ddot{\theta} + 2r \ddot{\phi} + 3g \phi = 0 $$
And I shall find the natural frequencies of small oscillations of Theta and Phi. Are you supposed to solve the equations, then check for where the frequencys diverge?
Solve for ##\ddot\theta## and ##\ddot\phi##. You will then have a linear system on the form
\ddot X = - A X,
where ##A## is a matrix and ##X## a column vector of size 2. What is the relation between that matrix and the natural frequencies?
It is unclear what you mean by "where the frequencies diverge".
Likes vanhees71
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
