Find the residues of the function
  • Thread starter Thread starter DanniHuang
    Function
The discussion revolves around finding the residues of the function f(z)=1/sin(z) at specific points: z=0, z=π/2, and z=π. Participants are exploring the nature of the poles and the methods for calculating residues at these points.
  • The original poster attempts to calculate the residue at z=0 and z=π/2, noting a simple pole at z=0 and questioning the method for z=π. Some participants suggest using series expansion around z=π and rewriting the sine function to facilitate the calculation.
Participants are actively discussing different methods to approach the residue at z=π, with some suggesting the use of limits and L'Hopital's rule. There is an ongoing exploration of how to apply these methods effectively, and while some guidance has been offered, no consensus has been reached on the best approach.
There is a mention of using computational tools to verify results, indicating a potential gap in understanding the manual calculation process. The discussion also reflects uncertainty about the application of methods used for other poles to z=π.
DanniHuang
f(z)=[itex]\frac{1}{sin(z)}[/itex] at z=0, [itex]\frac{∏}{2}[/itex], ∏
Since the function has a simple pole at z=0
I used: Res(f,0)=lim[itex]_{z->0}[/itex](z-0)[itex]\cdot[/itex][itex]\frac{1}{sin(z)}[/itex]=1. This means the residue of the function at z=0 is 1.
And Res(f,[itex]\frac{∏}{2}[/itex])=lim[itex]_{z->∏/2}[/itex](z-[itex]\frac{∏}{2}[/itex])[itex]\cdot[/itex][itex]\frac{1}{sin(z)}[/itex]=0. This means the residue of the function at z=[itex]\frac{∏}{2}[/itex] is 0.
However I think this method can not be applied on solving z=∏. How can I work it out?
Try expanding sin z in a series about ##z=\pi##. Or, better yet, use ##\sin z = \sin[(z-\pi)+\pi]##. The basic idea is to get everything in terms of ##z-\pi##.
If I turn everything into z-∏, do we need to use the same method as I used to work out z=0 and z=[itex]\frac{∏}{2}[/itex]?
But how? Turn the limit to z-∏→0?
Because I used computer to work out the answer of z=∏ which is -1. But I still cannot get this answer by myself.
You find the residue by evaluating the limit
$$\lim_{z \to \pi}\ (z-\pi)\frac{1}{\sin z}.$$ Rewriting the limit in terms of ##z-\pi## is simply to make the evaluation easier. I just realized you could simply apply L'Hopital's rule to do that and avoid unnecessary complications. If you had a more complicated function, however, writing things in terms of ##z-\pi## is often less work than using L'Hopital's rule.
But say you did it with using the trig identity anyway. You should end up with
$$\lim_{z\to\pi} \frac{z-\pi}{-\sin(z-\pi)}.$$ You might already recognize that limit, but it not, use the substitution ##w=z-\pi## to turn it into one you should recognize.
  • · Replies 23 ·
