Find the sinusoidal signal at specific frequency
To find the sinusoidal signal represented by the phasor V(x) = 8 + 4j at a frequency of 50 Hz, the correct expression is 8.944sin(100πt + 26.56°). The angular frequency ω is calculated as 2πf, resulting in ω = 100π. The phase angle θ is determined using tan^-1(4/8), yielding 26.56°. It's important to note that while radians are often preferred in calculations, using degrees is also acceptable in practical applications.
DODGEVIPER13
For a phasor V(x) = 8 + 4j find the sinusoidal signal that it represents if the frequency is 50 Hz?
sqrt(64+16)=8.944sin(50t) so clearly this is not correct?
8.944sin(100∏t+26.56)
where ω=2(pi)f=100(pi) and sin(ωt+θ) I found θ by tan^-1(4/8)=26.56°
Yup. That'll do it. Although strictly speaking you should indicate the units of the arguments to the sin function, since one is clearly radians and the other degrees...
8.944sin(100(pi)t+.463)
converted 26.56 to radians
oor would just doing 26.56°
Either way works. You're more likely to see the degrees version in practice.
