Find the sum of a geometric progression
  • Thread starter Thread starter mindauggas
    Geometric Sum
The discussion focuses on finding the sum of a geometric progression represented by the series 1/(1+x²) + 1/(1+x²)² + ... + 1/(1+x²)ⁿ. Participants analyze the reduction of the series to a common denominator and the application of the geometric series sum formula, identifying the first term and the common ratio. There is a debate about the necessity and extent of simplification, with suggestions to eliminate complex fractions for clarity. Ultimately, the correct form of the sum is confirmed as S_n = ((1+x²)ⁿ - 1) / (x²(1+x²)ⁿ). The conversation emphasizes the importance of simplification in mathematical expressions.
mindauggas
(1) \frac{1}{(1+x^{2})}+\frac{1}{(1+x^{2})^{2}}+...+\frac{1}{(1+x^{2})^{n}}
(2) \frac{1}{(1+x^{2})}*\frac{(1+x^{2})^{n-1}}{(1+x^{2})^{n-1}}+\frac{1}{(1+x^{2})^{2}}*\frac{(1+x^{2})^{n-2}}{(1+x^{2})^{n-2}}+...+\frac{1}{(1+x^{2})^{n}}*\frac{(1+x^{2})^{n-n}}{(1+x^{2})^{n-n}}
(3) \frac{(1+x^{2})^{n-1}+(1+x^{2})^{n-2}+...+(1+x^{2})^{n-n}}{(1+x^{2})^{n}}
Then I use the formula
{S(n)=\frac{n(n-1)}{2}}
I think i didn't do (2) correctly (reduction to a common denominator). Or did I?
What you're doing is unnecessary. You already know that the formula for the sum of a geometric progression is
S_n=\frac{a(1-r^n)}{1-r}
So what is r and a in this case?
Yeah I probably should have done it this way.
Both a and r are: \frac{1}{1+x^{2}}
Now 3 questions:
(1) Have I reduced sum to a common denominator correctly (previous post eq. (2))?
(2) Should I simplify the eq.:
S_n=\frac{\frac{1}{1+x^{2}}(1-\frac{1}{1+x^{2}}^n)}{1-\frac{1}{1+x^{2}}}
(3) How to know when to leave the exercise, what is the rule of thumb to remember on how much to simplify?
By all means you should simplify. I don't consider a complex fraction to be in simpliest form. Can you simplify so that neither the numerator or denominator contain fractions?
Yes you have correctly found the common denominator in (2).
You should definitely cancel out the \frac{1}{1+x^2} in both the numerator and denominator. From there, I think it would be fine, if you go further as to get rid of the fraction in the numerator then you're going to have two (1+x^2)^n terms and some would argue that it isn't as neat.
I went:
(1) S_n=\frac{\frac{1}{1+x^{2}}(1-\frac{1}{1+x^{2}}^n)}{\frac{1+x^{2}}{1+x^{2}}-\frac{1}{1+x^{2}}}
At the end got:
(2) S_n=\frac{1-\frac{1}{1+x^{2}}^{n}}{x^{2}}
Can I do smth. more (I doesn't seem to me)? Or should i do something different? Is there a way to get rid of the fraction in the numerator?
In exactly the same way that you would get rid of the fraction in an expression such as this,
\frac{1+\frac{1}{x}}{y}
Continuing:
S_n=\frac{1-\frac{1}{(1+x^{2})^{n}}}{x^{2}}
Got:
S_n=\frac{(1+x^{2})^{n}}{x^{2}(1+x^{2})^{n}-1}
Is this correct?
Probably should have written a few more steps:
(1) S_n=\frac{1-\frac{1}{(1+x^{2})^{n}}}{x^{2}}
(2) S_n=\frac{\frac{(1+x^{2})^{n}}{(1+x^{2})^{n}}-\frac{1}{(1+x^{2})^{n}}}{x^{2}}
(3) S_n=\frac{\frac{(1+x^{2})^{n}-1}{(1+x^{2})^{n}}}{x^{2}}
(4) S_n=\frac{x^{2}(1+x^{2})^{n}-1}{(1+x^{2})^{n}}
Is this the form that I should leave it in?
It should be
S_n=\frac{(1+x^{2})^{n}-1}{x^{2}(1+x^{2})^{n}}
Yes, my bad.
Thank you all for the help.
