Find the volume of the solid which is bounded by the cylinders
The discussion focuses on finding the volume of a solid bounded by the equations of two intersecting cylinders, x^2 + y^2 = r^2 and y^2 + z^2 = r^2. Participants clarify that these equations represent right circular cylinders, with "r" being a constant for the purpose of volume integration. The importance of visualizing the solid through drawings is emphasized to aid in understanding the limits of integration. One participant mentions the lack of coverage on cylindrical and spherical coordinates in their study material, seeking alternative methods for solving the problem. Overall, the conversation revolves around interpreting the equations and understanding the geometric implications of the solid formed by the intersecting cylinders.
Benny
Q. Find the volume of the solid which is bounded by the cylinders x^2 + y^2 = r^2 and y^2 + z^2 = r^2. To me they don't really look like equations of cylinders, more like circles. Would the term "r" be constant in this case? Or would it be a variable? Even if r is a variable, I don't understand why the equations contain its square, rather than just "r" itself. Are the given equations standard equations for a clinder?
I'm just having trouble interpreting the equations at this stage. Help would be apppreciated.
Yes,as you can see,in the first equation,the "z" variable is free to take any real value.That means that the circle x^2 +y^2 =r^2 is free to move along the "z" axis,and thus generating a surface called "right circular cylinder".
The same goes for the other equation.So you've got 2 intersecting right circular cylinders and you need to find the volume.Better make a drawing to find the limits of integration and then choose cylindrical coordinates.
Daniel.
Thanks for the help dex. Although, up to the section of my book from which I got this question, cylindrical and spherical coordinates haven't been covered yet. I'll see if I can find another way around this one.
Here's a picture of your solid
http://mathworld.wolfram.com/SteinmetzSolid.html
plus a lot more, unfortunately. See if you can work it out for yourself once you understand the shape before you just take the solution. r is constant for the integration. Of course the volume depends on r.
