Find the wavelength of the blue line (line spectrum)
The discussion focuses on determining the wavelength of the blue line in a line spectrum consisting of blue, yellow, and red lines. Using a diffraction grating with a known spacing, the angles for the fifth and seventh lines were provided, allowing for the calculation of the sixth line's wavelength. The confusion arises regarding the order of the blue line, with participants clarifying that the first blue line corresponds to the first order. Ultimately, substituting the correct order into the wavelength formula yields a wavelength of approximately 4.34 * 10-7 m for the blue line. The conversation emphasizes the importance of understanding fringe order in relation to different colors in the spectrum.
moenste
The line spectrum of a certain substance consists of three prominent lines; blue (B), yellow (Y) and red (R). When the spectrum is examined with a diffraction grating having d = 4 * 10-6 m, it is found that the sequence of lines, moving from the centre, is B, Y, R, B, Y, B, R.
Further, it is found that the diffraction angles θ of the fifth and seventh lines are 17.46° and 20.49° respectively, and that the sixth line is at an angular position exactly halfway between them. Find the wavelength of the blue line.
Answer: 4.34 * 10-7 m
2. The attempt at a solution
We find the θ6 = (17.46 + 20.49) / 2 = 18.975°. Then plug into the formula: n λ = d sin θ to find the wavelength of the sixth line: λ6 = (4 * 10-6 * sin 18.975°) / 6 = 2.168 * 10-7 m.
I also found the wavelengths for the fifth and seventh lines: 2.4 * 10-7 m and 2 * 10-7 m respectively.
But after this I don't know what to do. I need to find the wavelength of the first blue line, while I have the wavelengths of a yellow (5), blue (6) and a red (7) one. How to use them to find blue (1)?
No, you don't use n=6. The fringe order is for only one color. Overall taking into account all colors, the sixth line is blue, but which order does this blue appear from the center?
Likes moenste
B is the first color, so it should be the first order?
What I meant is, should you remove the other colors beside blue, what will be the order of the 6th line blue?
Likes moenste
If you put it like that, it should be the third order.
And indeed if we plug in 3 instead of 6 we'll get 4.33 * 10-7.
Thank you!
