Find the wavelength of the particle
To find the wavelength of a particle accelerated by a potential difference V, the de Broglie wavelength formula λ = h/mv is relevant, where m is the relativistic mass. The kinetic energy gained from the potential difference is converted into kinetic energy of the particle, expressed as 0.5mv². There is confusion about whether the particle maintains a constant speed after acceleration or continues to accelerate. Clarification on the relativistic effects is needed, as the discussion indicates a lack of depth in understanding these concepts. Understanding these principles is essential for solving the problem correctly.
fluidistic
I'm not even sure the problem is about matterwave:
A particle of mass m and charge e is accelerated by a potential difference V. Find the wavelength of the particle. Show that this result agrees with the classical one when the non relativistic limit is taken.
Not sure, but I think that \lambda _B=\frac{h}{mv} where m is the relativistic mass, i.e. m=\gamma m_0.
Maybe F=qE?
I'm not really sure how to find the motion equation of the particle and I need its velocity in order to calculate its de Broglie's wavelength. F=qE.
\Delta V =\int _A^b \vec E d \vec l... I don't go anywhere that way.
I've no idea what I'm missing.
The energy produced by the pd is Ve, which is converted into ke of the particle (0.5mv2).
Thank you. Ah, very similar to an exercise I started 2 days ago and you helped me...
However isn't the kinetic energy worth c^2 (m-m_0)? Furthermore that would give a constant kinetic energy while they state "accelerated". Do they mean accelerated up to a speed v and then the particle maintains this speed constantly?!
I believe that is what it meant. I am not sure about the relativistic aspect though (never learned about it in depth).
Thank you for all your help.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
