Where to Find Thermocouples for Power Generation in Stores or Online?
  • Thread starter .:Endeavour:.
In summary, thermocouples can be found at a store or can be made at home by using household items. They can be used to generate electricity during the summer.
.:Endeavour:.
80
I want to know where can you find thermocouples in a store to buy or can you make them by using house hold items? The reason why I want to buy or make one is to use it during summer to generate electricity durning the hot weather.
http://www.omega.com/" is a good place to find theromcouples. You will not find them useful as a powersource in the summer or any other time. what they can do with proper elctronics is tell you how hot it is.
They are really easy to make though and all you need is two different metals ,usually wires, joined at two different places.Copper and constantan(an alloy) is a common combination
Is there a diagram on how to make one. Because I've been Googling thermocouple but I didn't get a solid description on how to make one except that you need a difference of temperature for it to work which I think I know where to get the two different temperatures. Thank you for your help.
It's dirt easy. Solder or weld two wires of different metals together. Stick the soldered end into something that's hotter or colder then the other end of the two wires and that's enough so there is a minute voltage between the free ends.
Make a long zig zag of alternating wires between the two temperatures to multiply the voltage. This is called a thermopile. The Voltage is #&^#$ small, so unless you are planning a whole furry wire coat around something you are planning to get the thermal energy from, you will be able to run a quartz clock at best.
Can you show me how you make a thermocouple. I do understand what you're saying only that I would like something visual to make reference on so I know I'm doing it correctly.
Her you go :)
http://www.madwizard.org/images/content/el/reflowoven/thermocouple.jpg
The other end of the wires where you take out the voltage needs to be colder/or warmer. If you use a cable with two wires of the same metal to transport the voltage away from the thermocouple the point that counts and needs to be colder is the contact point of your cable to the thermocouple. Just search for thermopile to get pictures of those. I liked a drawing from a paper from 1912 a lot, but I cannot find it anymore.
But there is quite a few pictures on google even if you discard all the commercial ones, which are encased and don't show anything.
1. What is a thermocouple and why would I need one?
A thermocouple is a type of temperature sensor that consists of two different metal wires joined together at one end. It is used to measure temperature in a variety of applications, such as in industrial processes, laboratory experiments, and home appliances.
2. Where can I find thermocouples in a store?
Thermocouples can be found in many stores that sell electronics, industrial supplies, or scientific equipment. Some specific places to look include hardware stores, home improvement stores, and specialty stores that cater to scientists or engineers.
3. How do I know which type of thermocouple to buy?
The type of thermocouple you need will depend on the temperature range you want to measure and the environment in which it will be used. There are several different types of thermocouples, each with its own temperature range and level of accuracy. It is important to consult with a knowledgeable salesperson or do some research to determine the best type for your specific needs.
4. Can I purchase thermocouples online?
Yes, many online retailers offer thermocouples for sale. However, it is important to make sure you are purchasing from a reputable source to ensure the quality and accuracy of the thermocouple.
5. How much do thermocouples typically cost?
The cost of a thermocouple can vary depending on the type, size, and brand. On average, a basic thermocouple can range from $10 to $50, while more specialized or high-precision thermocouples can cost up to several hundred dollars.
  • Electrical Engineering
  • Mechanical Engineering
