Find values so that the vector has the specified angle
  • Thread starter Thread starter Calpalned
    Angle Vector
Calpalned
Find the values of x such that the angle between the vectors <2, 1, -1>, and <1, x, 0> is 45 degrees.
<2, 1, -1> dot <1, x, 0> = 2 + x
|first vector| = (6)0.5
|2nd vector| = (1 + x2)1/2
Angle = cos-1(a dot b)/(|a||b|)
Cosine of 45 is the root of two divided by two.
I set (2 + x) divided by 6^0.5 and (1 + x2)^0.5 equal to 1 divided by the root of 2.
I eventually get 2√2 + x√2 = √6√1 + x2
Am I on the right track?
Or equivalently, ##\frac{2 + x}{\sqrt{6}\sqrt{1 + x^2}} = \frac{\sqrt{2}}{2}##
I'm not sure about the above, although it might be right. I get a quadratic with all integer coefficients.
Can you show what you did going from your equation above to this one?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
