Find Vc(0): Node Analysis & Ohms Law
The discussion revolves around finding Vc(0) using node analysis and Ohm's Law. Participants suggest expressing Vo in terms of other circuit quantities, emphasizing the importance of order of operations. There is confusion about replacing Vo with different expressions, and clarification is provided regarding the correct interpretation of branch currents. The conversation highlights the need to accurately identify relationships between voltages and currents in the circuit. Ultimately, the focus remains on correctly applying node analysis to solve for Vc(0).
sammyqw
find Vc(0)
Node analysis , ohms law
Hi, I'm trying to find Vc(0). I used node analysis but I'm stuck in eq 1. I'll appreciate if someone can give me some suggestions. Thanks
Looks like you need to replace Vo with something. Go back to your schematic and see if you can express Vo in terms of the other quantities pertaining to the branch it's in.
Can I replace Vo with V-10/25 ?
Do you mean (V-10)/25? (Order of operations is important). No, that would be the branch current flowing from v towards the 10 V source. But that's a start. What would be Vo in terms of that current?
it would be some current i = Vo/20 ?
That's the idea. But you've already identified the branch current in post #3.
Can I do i=10/25 = 0.4A then find Vo= (0.4)20 =8V and then just replace it in my equation 2?
No because the battery voltage is not across the branch. What is an expression for the branch current (you wrote one as a term in your node equation!)?
