Finding a Basis for Subspace in R^4: Linear Algebra Tips
4 replies · 2K views
xsqueetzzz
Help! Find a basis.
Find a basis for the subspace of R^4 spanned by, S={(6,-3,6,340, (3,-2,3,19), (8,3,-9,6), (-2,0,6,-5)
Figured I would set up the linear combination to test for independence.
Do you know how to set up these four vectors as columns to make a 4x4 matrix?
Have you done row reducing?
Because that would also be an approach to determining if they are linearly independent.
I made up the columns, solved for rref, and came up with the trivial solution
As long as you got it to RREF, then you can see if there is a pivot in each column, if there is, then these vectors span R4. If there is not a pivot in each, then they do not span R4.
Good luck!
If the determinant of the matrix these vectors make is 0 then some of them are linearly dependent.
