Finding a Power Series for a function
aerospacev
Find a power series representation for the function f(x) = \frac{(x-1)}{(3-x)^2}^2, valid for every x with |x|<3
The equation that I think would be useful is \frac{1}{1-x} = \sum_{n=0}^\infty x^n
I began by just looking at the term \frac{1}{(3-x)^2}
differentiating both sides:
\frac{1}{(1-x)^2}= \sum_{n=1}^\infty nx^{(n-1)}
now I'm stuck here, my train of thought is that if I can turn \frac{1}{(3-x)^2} into someform of \frac{1}{(1-x)^2} to obtain its summation formula, I can then multiply the polynomial {(x-1)}^2 to that summation and go from there.
Usually the assignment questions involve functions in the likes of \frac{x}{(1-x^2)} or \frac{x^2}{(1+x)^3}, which I can solve, but the 3 in front of the x in \frac{1}{(3-x)^2} is really troubling me, any help? Thanks!
Hi aerospacev!
You can factor out the 3 from the denominator and write it as following:
$$f(x)=\frac{(x-1)^2}{9}\frac{1}{(1-x/3)^2}$$
Can you proceed now?
I wondered about that, maybe I need to review my basic arithmetic, am I allowed to simply divide each number individually in {(3-x)^2} by 3 and multiply by 3^2? Even though the entire term is squared?
I am not sure what you mean there. What I did is the following:
$$(3-x)^2=\left(3\left(1-\frac{x}{3}\right)\right)^2=3^2\left(1-\frac{x}{3}\right)^2=9\left(1-\frac{x}{3}\right)^2$$
I hope that helps.
$$(3-x)^2=\left(3\left(1-\frac{x}{3}\right)\right)^2=3^2\left(1-\frac{x}{3}\right)=9\left(1-\frac{x}{3}\right)$$
I hope that helps.
Hi Panav-Arora.
I think you want to correct those last two versions of the right hand sides, to have an exponent of 2.
Chet
Likes 1 person
Chestermiller said:
Hi Panav-Arora.
Chet
Woops, thanks Chet! :D
I hope that helps.
Oh ok thanks, I think there was just some confusion on my part.
I got the correct answer, thanks again!
How about
##f(x) = (\frac{x-1}{3-x})^2 = (\frac{x}{3-x}-\frac{1}{3-x})^2##
## = (\frac{-1}{1-(\frac{3}{x})}-\frac{(\frac{1}{3})}{1-(\frac{x}{3})})^2 ##
##so, f(x) = [-\sum\limits_{n=0}^∞ (\frac{3}{x})^n - \frac{1}{3}\sum\limits_{n=0}^∞ (\frac{x}{3})^n]^2 ## where ##-3 < x < 3##
vanceEE said:
How about
I don't think so, wouldn't you then have to divide by zero?
Also, even if the calculation is correct,
$$[-\sum\limits_{n=0}^∞ (\frac{3}{x})^n - \frac{1}{3}\sum\limits_{n=0}^∞ (\frac{x}{3})^n]^2$$
is not a power series as written. It is a expression involving power series, but that's not the same thing.
Divide what by zero? The index of summation n = 0 means that we would first have a zero as an exponent. This series isn't convergent, an error on my part, but there is nothing being divided by zero in this series; x ≠ 0.
But the original problem statement says "valid for every ##x## with ##|x|< 3##", so that includes ##x=0##.
