Finding A Second Solution For A DE Via Reduction Of Order
  • Thread starter Thread starter Lancelot59
    Reduction
Lancelot59
I'm given
y''-4y'+4y=0
and there is a solution y_{1}=e^{2x}
Using this I need to find a second solution.
Starting with the assumption:
y_{2}=u(x)*y_{1}
Then:
y=ue^{2x}
y'=2ue^{2x}+u'e^{2x}
y''=4ue^{2x}+2u'e^{2x}+u''e^{2x}+2u'e^{2x}
When I substitute back into the original equation, after doing the cancellation I wind up with:
u''e^{2x}=0
Then using the following order reduction:
w=u'
I get:
w'e^{2x}=0
I'm not sure what to do next here. The example in my textbook had two terms, and they used an integrating factor. How can I go about solving this problem? The answer given in the book is:
y_{2}=e^{2x}
so
w' e2x=0
reduces to
w'=0
which is easy to solve
the answer given is wrong it should be
y2=(a x+b)e2x
where a and b are any numbers except a is not 0
I actually found a silly algebra error, so there should be two terms. However the answer is even stranger. I'll talk to my prof about it, thanks for looking!
You were right the first time
w' e2x=0
reduces to
w'=0
notice when y is a solution so is y'-2y or conversely when
y'-2y=e2x
y is a solution of
y''-4y'+4=0
w' e2x=0
reduces to
w'=0
y'-2y=e2x
y is a solution of
y''-4y'+4=0
I guess that does work. Thanks!
EDIT: I'm not sure how though. You have that w'=0, but how do you then solve for y being e^2x?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
