Finding Absolute Uncertainty Using Formulas
The discussion revolves around calculating the volume and absolute uncertainty of a sphere given its circumference and associated error. The user initially solved the problem by averaging volume values derived from the low and high circumference measurements, resulting in a final volume of 0.01589 m³ with an uncertainty of ±0.00049 m³. However, they seek clarification on using specific formulas for absolute uncertainty involving constants and exponents, expressing confusion over the necessity of these methods. The conversation also touches on the formatting of mathematical expressions in forum posts. Understanding the formulas for calculating uncertainty is essential for accurate scientific reporting.
Coop
Hello,
I have solved the problem, but not the way the writer intended. I need help figuring out how they wanted me to do it.
Here's the problem:
The circumference of a sphere is found to be 0.98 m +/- 0.01 m. Calculate the volume and absolute error with five digits to the right of the decimal.
C = 2∏r
V = (4/3)∏r3
I used the low end (.97 m) and high end (.99 m) circumference measurement to solve for two radii. Then I plugged those into the volume equation and got to volume values: .01541 m3 and .01639 m3. Averaging those volumes I found the final volume to be .01589 m3.
To find the absolute uncertainty I merely subtracted the high end circumference value from the low end one and divided by two.
∴ volume = .01589 m3 +/- .00049 m3.
But my question is, they wanted me to find absolute uncertainty using the following formulas:
Δ[constant]X = [constant]*ΔX to account for constants
(Δtotal/final value) = |n| * [(ΔX)/X] to find uncertainty values where n is an exponent on A
ΔX = [(ΔX)/X] * X to convert from relative to absolute error
...where Δ stands for uncertainty
How would I do this?
It seems a lot more confusing for no reason, but would there be any case when I wouldn't be able to use my method and would have to use these formulas?
P.S. Is there anyway to code when writing these? Like I know for some help sites you can input fractions using commands like \frac{num.}{denom.}
What does this even mean, "circumference of a sphere"?
As to your question, what exactly is unclear in the formulae given to you?
To see how to enter stuff like ##V = \frac 4 3 \pi r^3 ##, click the quote button.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
