Finding all vectors normal to a given set of vectors
mds9668
How do you find all vectors perpendicular to a set of three vectors in R^4? I know that the dot product of a normal vector and each given vector will be equal to 0. How could I set up the system of equations in matrix form?
Hmm, you just have to write out the equations for each dot product. For example, suppose the three vectors are v_1, v_2, v_3. Then let the perpendicular vector be u. So we know that u \cdot v_i = 0. Let u = (a_1, a_2, a_3, a_4)^T for concreteness.
So if v_1 = (x_1, x_2, x_3, x_4)^T, then we have, after applying the dot product of u and v1:
a_1 x_1 + a_2 x_2 +a_3 x_3 + a_4 x_4 = 0. Do the same for the other two vectors and you have a system of equations which you can then express in matrix form.
could you not cross product??
I believe the cross product is defined only in R^3, well as far as i know :P
Defennder said:
It's defined in R3 and R7 only, if I remember correctly. I don't know why, though. See here:
http://en.wikipedia.org/wiki/Cross_product#Higher_dimensions
As the Wiki article says, there's more than one way to extend the cross product to higher dimensions. One very straightforward way extends it to all dimensions of Rn, but it's a little peculiar: In dimension n it becomes a function of n-1 vectors rather than a simple product of two vectors. This is mentioned in Spivak's classic monograph, Calculus on Manifolds, chapter 4, p83 in the old Benjamin edition. I'll quote the relevant snippet here:
If v_1, ..., v_{n-1} \in R^n and \phi is defined by
<br /> \phi(w) = det \left( \begin{matrix}<br /> v_1 \\<br /> ... \\<br /> v_{n-1} \\<br /> w<br /> \end{matrix} \right)<br />
then \phi \in \Lambda^1 (R^n); therefore there is a unique z \in R^n such that
<br /> \langle w,z \rangle = \phi(w) = det \left( \begin{matrix}<br /> v_1 \\<br /> ... \\<br /> v_{n-1} \\<br /> w<br /> \end{matrix} \right) <br />
This z is denoted
<br /> v_1 \times ... \times v_{n-1}<br />
and is called the cross product of v_1, ... v_{n-1}.
Welcome to PF!
Hi mds9668! Welcome to PF! :smile:
You use the wedge product, ⋀, of all three vectors (with x⋀x = 0).
That will give you a 3-form, which is a linear combination a.x⋀y⋀z + b.y⋀z⋀t + c.z⋀x⋀t + d.x⋀y⋀t.
The vectors perpendicular to all three will be the multiples of a.t + b.x + c.y + d.z
(because (a.t + b.x + c.y + d.z)(a.x⋀y⋀z + b.y⋀z⋀t + c.z⋀x⋀t + d.x⋀y⋀t) = a² + b² + c² + d²) :smile:
