How to Find the Operator A2 for A = d/dx + x
  • Thread starter Thread starter terp.asessed
    Operator
terp.asessed
Hello--I am practicing for the upcoming quiz (as part of quantum physics), but have no idea how to solve the sample problem the teacher gave (w/ solution)...
Write out the operator A2 for A = d/dx + x
(Hint: INCLUDE f(x) before carrying out the operations)
so...I tried:
A {df(x)/dx + f(x)} = d/dx{df(x)/dx + f(x)} + df(x)/dx + f(x)
= d2f(x)/dx2 + df(x)/dx + df(x)/dx + f(x)
= d2f(x)/dx2 + 2df(x)/dx + f(x)
...when the solution is A2 = d2/dx2 + 2xd/dx + 1 + x2
...where did I make mistake? Could someone please point out? Thanks!
Here, right at the beginning:
You've expanded ##A f## as ##\frac{\mathrm{d}}{\mathrm{d}x} f + f##. It should be ##A f = \frac{\mathrm{d}}{\mathrm{d}x} f + x f##.
Likes terp.asessed
Thanks! But, I still have trouble getting all the solution values:
A f(x) = df(x)/dx + xf(x)
= d (df(x)/dx + xf(x))/dx + x df(x)/dx + x2f(x)
= d2f(x)/dx2 +x df(x)/dx + x df(x)/dx + x2f(x)
= d2f(x)/dx2 +2x df(x)/dx + x2f(x)...I could NOT get (+1) part from the solution: A2 = d2/dx2 + 2xd/dx + 1 + x2
...How do I get (+1) value? Did I leave out some values while I tried to solve for A2?
A2f(x) = d (df(x)/dx + xf(x))/dx + x df(x)/dx + x2f(x)
You didn't apply the first ##\frac{d}{dx}## correctly between the last two lines.
Wait, thank you for correcting my first mistake, but I still don't see how I got the last two lines wrong...
Thank you for correcting my first mistake, forgetting to add A2 f(x), but I still cannot see how I got last two lines wrong
...could you pls clarify more? Thanks.
You should get two terms out of
\frac{d}{dx} \left( x f(x) \right)
So, I should have gotten d(xf(x))dx, NOT x df(x)/dx?
d(xf(x))dx = xdf(x)/dx + df(x)/dx?
I redid from the beginning, but I still cannot get (+1) part:
A2f(x) = d2f(x)/dx2 + df(x)/dx + 2xdf(x)/dx + x2f(x)
I got df(x)/dx INSTEAD of 1...or rather f(x) in the case of A2f(x)...
I'm not sure what you mean here. You have written yourself the first term of ##A^2 f(x)## as d (df(x)/dx + xf(x))/dx, meaning
\frac{d}{dx} \left( \frac{d f(x)}{dx} + x f(x) \right)
which expands to
\frac{d}{dx} \left( \frac{d f(x)}{dx} \right) + \frac{d}{dx} \left( x f(x) \right)
It is the second term there that you do not calculate properly.
What is ##
\frac{d}{dx} \left( f(x) g(x) \right)
Likes terp.asessed
What is ##
## ?[/QUOTE]
d(f(x)g(x)/dx = g(x)df(x)/dx + f(x) dg(x)/dx?
Correct, now apply it to your problem by setting ##g(x) = x##.
GOTCHA! Finally got the result:
A2f(x) = d2f(x)/dx2 + f(x) + 2xdf(x)/dx + x2f(x)
Also, one more question...if A = 2x d/dx...just in case...is it:
Af(x) = 2x df(x)/dx
OR
=2xf(x) df(x)/dx?
Af(x) = 2x df(x)/dx
OR
=2xf(x) df(x)/dx?
You can see that A as a combination of operators, ##\hat{A} = \hat{B} \hat{C}##, with ##\hat{B} \equiv 2x##, meaning "multiply by ##2x##," and ##\hat{C} \equiv \frac{d}{dx}##, meaning "differentiate with respect to ##x##." These operators are to be applied in sequence, starting from the right-most and moving to the left, meaning here "differentiate with respect to ##x##, then multiply the result by ##2x##." Therefore your first line above is correct.
Likes terp.asessed
Thank you very much!
