Finding Center of Mass for Composite Shapes
To find the center of mass for composite shapes, the integral M(Rcm) = ∫(r dm) is essential, where dm represents mass elements. One participant suggests using a conceptual approach by treating cut-outs as "negative" masses that push the center of mass away from them, simplifying the calculation. This method involves calculating the center of mass of the entire shape and adjusting for the cut-outs as if they were separate particles with negative mass. The discussion emphasizes that sometimes intuitive reasoning can be more effective than complex mathematics in solving such problems. Overall, understanding the relationship between mass distribution and geometry is key to determining the center of mass accurately.
Darkalyan
http://docs.google.com/Doc?id=d277r7r_60c2235gfg
<br /> <br /> M(Rcm)=\int(rdm)<br /> <br />
Okay, so I've figured out that I have to integrate the radii by the mass element dm, which in this case would be p, because that's the mass/unit area? I think that's right, but even there I'm not sure and the actual integral itself I have no idea how to do for such a weird shape.
I wouldn't integrate if I were you. There's a way to know where's the center of mass without much mathematics. Thinking is more powerful than mathematics, sometimes.
Hmm. Could I take the center of mass of the entire circle, assuming there's no cut outs. Then I take the center of mass of the cut-outs, and pretend they act like 'negative' masses, so instead of having the centerr of mass of the composite system get closer to them, they are farther away? So basically pretend this is a 3 particle system and combine the locations of the center of masses, but assume the cutouts have 'negative' masses, so they push away the center of mass instead of bringing it closer?
Exactly.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
