Finding composite derivatives
So the correct answer is (f\circ g)'(-2)=-2.Similarly, (g\circ f)'(2)=g'(f(2))g'(2)=g'(3)(2)=(-4)(2)=-8.In summary, using the chain rule, the derivative of a composite function (f\circ g) is equal to the derivative of the outer function (f) evaluated at the inner function (g(x)) multiplied by the derivative of the inner function (g'(x)). Applying this to the given equations, we can find that (f\circ g)'(-2)=-2 and (g\circ f)'(2)=-8.
steve snash
50
a) (f ° g)′(−2) = ?
b) (g ° f)′(2) = ?
f(−2) = −3,
g(−2) = −4,
f(2) = 3,
g(2) = −3,
f ′(−2) = −1,
f ′(−4) = −2,
f ′(2) = 5,
g ′(−2) = 1,
g ′(2) = 2,
g ′(3) = −4.
I have no idea how to do it every thing I've tried doesn't work, how do you work it out. Could someone explain the processes so i know how to do any derivative of a composite function
Just use the chain rule...
[tex](f\circ g)(x)=f(g(x))\implies\frac{d}{dx}(f\circ g)(x)=\frac{d}{dx}f(g(x))=\frac{df(g)}{dg}\frac{dg}{dx}=f'(g(x))g'(x)=(f'\circ g)(x)g'(x)[/tex]
i would take the composition of functions to mean:
[tex]f \circ g(x) = f(g(x))[/tex]
using the chain rule, what is
[tex]\frac{d}{dx}f(g(x))=?[/tex]
that makes the answer (f o g)'(-2)= f(-2)(g(-2))(g'(-2))
= -1(-4)x(1)
which = 4 which is the wrong answer =(
= -1(-4)x(1)
No, [itex](f'\circ g)(-2)=f'(g(-2))=f'(-4)[/itex]
1. What is a composite derivative?
A composite derivative is a mathematical concept that involves finding the derivative of a function that is composed of two or more other functions. In other words, it is finding the rate of change of a function that is made up of other functions.
2. Why is finding composite derivatives important?
Composite derivatives are important because they allow us to analyze the behavior of complex functions and make predictions about their future values. They are also necessary for solving many real-world problems in fields such as physics, economics, and engineering.
3. How do you find a composite derivative?
To find a composite derivative, you can use the chain rule, which states that the derivative of a composite function is equal to the derivative of the outer function multiplied by the derivative of the inner function. Alternatively, you can use the quotient rule or product rule if the composite function involves division or multiplication, respectively.
4. What are some common mistakes when finding composite derivatives?
Some common mistakes when finding composite derivatives include forgetting to apply the chain rule, using the product or quotient rule incorrectly, and making errors in algebraic simplification. It is important to carefully follow the rules for finding derivatives and double-check your work for accuracy.
5. Are there any tips for finding composite derivatives more efficiently?
Yes, there are a few tips that can help you find composite derivatives more efficiently. First, make sure to clearly identify the outer and inner functions and use the appropriate rule (chain, product, or quotient) for each. Additionally, practicing and familiarizing yourself with common functions and their derivatives can help you recognize patterns and solve problems more quickly.
