Finding conservation of energy through Newton's Law.
The discussion focuses on designing a lab to demonstrate the conservation of energy using Newton's laws. The participant struggles to connect velocity calculations from acceleration with the conservation of energy formula. Key equations for kinetic and potential energy are identified, but challenges arise due to the initial velocity being zero in a free-fall scenario. Suggestions include measuring mass, height, and time to calculate acceleration and final velocity, confirming that energy conservation principles will hold true regardless of the specific measurements. Ultimately, the experiment may only confirm constant acceleration rather than directly proving conservation of energy.
D3xus
I'm devising a lab to find/prove the conservation of energy through one of Newton's laws. I can substitute variables when do the lab, but I need to design it first before I assign variables or data.
K.E.(initial) + P.E(initial) = K.E.(final) + P.E.(final)
X = x(initial) – v(initial)t + ½*a*t^2
v = a/t
I assumed that you could find the velocity (to be used in the conservation of energy formula) from the acceleration formula, and plug it into the Newton's law formula, but that didn't work out. I'm at a stalemate and need some help forward.
Thank you.
To verify the conservation law as you've written it, you will need expressions to define the KE and PE (these are not defined by Newton's laws). I think you're also going to have to assume that g is constant (within the lab).
What went wrong with your attempt?
For K.E and P.E I used 1/2 m*v^2 and mgh respectively.
With my attempt, I realized that because, in the system I was trying to work with (free fall), the initial velocity was zero, so I couldn't prove that the net forces in a system before and after were the same.
Is there a way to use some variable or aspect of the conservation of energy formula in a Newton's Law formula?
Not sure what to advise on this. If you measure mass, height and time, and assume constant acceleration, you can use Newton's equations of motion to calculate the acceleration (a) and final velocity. You can then calculate the final KE, but it will inevitably equal mah. I.e., it doesn't matter what height and time you measure, you cannot get a result that contradicts conservation of energy. So it would not constitute a lab experiment which verifies conservation.
You could conduct tests with different heights, but that will only serve to confirm the acceleration is constant.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
