Identifying Critical Numbers for Square Root and Rational Functions
  • Thread starter Thread starter tjohn101
    Numbers
tjohn101
Find all critical numbers of:
g(x)= sqrt(x2-4)
and
f(x)= (1)/(x2-9)
n/a
1) sqrt(x2-4)
simplified to x(x-2)(x+2)-1/2 (please check)
and got zeroes as x=0, x=2, x=-2
and I got confused because if you do g(2) and g(-2) it equals zero. For some reason I can't tell if they are defined or undefined. x=0 works, so that is a critical number. The other two are throwing me off.
2) (1)/(x2-9)
zeroes were x=-3, x=3, x=0. Plugging 3 and -3 back into f(x) gave me undefined, so I'm pretty sure 0 is the only critical number.
If you could please check the second and help with the first that would be great. Thank you
About
"1) sqrt(x2-4)
simplified to x(x-2)(x+2)-1/2"
- is that supposed to be the derivative of \sqrt{\,x^2 -4}? if so, it isn't correct.
what is your definition of a critical value? (writing it out can help you see the appropriate path)
I'm honestly not sure what I did there... I re-did my derivative and found
x/((x2-4)1/2)
which would go to x/(((x+2)(x-2))1/2)
and give zeroes of -2,2,0. -2 and 2 would make the denominator 0 and be undefined, leaving 0 as the only CP. Sound right? Sorry if any errors I did that really quick.
yes, the derivative is
<br /> \frac{x}{\sqrt{\, x^2 - 4}}<br />
and this is zero or undefined for 0 \text{ and } \pm 2.
Again, what is your definition of a critical number? (same as critical value)
Definition is:
x=c is a critical number for f(x) if f(c) is defined and f'(c)=0 or f'(c) is undefined.
So that means 2 and -2 WOULD be CPs?
tjohn101 said:
Definition is:
yes.
And 0 would not be one because it is undefined in f(x) (sqrt of a negative makes it undefined), correct?
And for the second problem, zero was the only one defined in f(x). Therefore it IS indeed a CP.
