Finding Derivatives with Respect to a Variable
10 replies · 3K views · last reply
ialan731
The question says ti find the derivative of y with respect to the independent variable.
The equation is: y=4 ln 2t.
I know how to find derivatives using the product/quotient/chain/etc rules, but that isn't what the question is asking for. I though it wanted me to use implicit differentiation, but that doesn't really make sense because y is explicitally defined in terms of x. I don't really know what should be used.
Before, I tried to just get the derivative normally and got 4 ln 2t +2/t, but that's not right. Then I also tried using implicit differentiation, but it wasn't working.
By the way, the answer is (ln4/t)4 ln 2t
Thank you in advance!
What's the derivative of ln(x) ?
If you know the derivative of that, then you can simply apply the chain rule.
[tex]\frac{dy}{dx} = 4\frac{d}{dx}ln(2x)[/tex]
recall that [tex]\frac{dy}{dx} = \frac{dy}{du}\frac{du}{dx}[/tex]
The derivative of ln(x) is 1/x.
Am I supposed to use implicit differentiation, then? Or is the chain rule enough?
The chain rule is plenty.
What you can do is simply use a substitution. Let some function U(t) equal the "contents" of the original (ln) function.
Then find the derivative of ln(U), then apply the chainrule.
The derivative of ln(U) would just be 1/U then. I would only be working with the equation 4ln(U). After I use the chain rule for that equation, would I substitute the original ln function?
4 is a constant so it just comes outside, then let f(x) = ln(U), and let U(x) = 2t then simply recall the chain rule:
[tex]4\frac{df}{dx} = 4\frac{df}{du} \frac{du}{dx}[/tex] //I just multiplied in a 4 there for the constant
Okay. I get it now. This would work for all problems like this, right?
Well yes. Technically you ALWAYS are using the chain rule. It's just that for cases like the derivative of y=x (y'=1), the "inner product" or composite function's derivative is just 1 also.
If you have a ton of functions, let's say something like this:
y = x, x = t, t = p
You can see that you could just substitute it all in, or you can simply follow the chain rule:
[tex]\frac{dy}{dp} = \frac{dy}{dx} \frac{dx}{dt} \frac{dt}{dp}[/tex]
and so on, up to an infinite number of nestled composite functions.
Great! This was the one thing I was worried about, but it doesn't seem to be too bad now. Thank you!
