Finding displacement of the string given a function
The discussion revolves around finding the displacement of a string wave described by the function y=(2x)/(x^2+50) at a specific time and position. The wave propagates at a speed of 10 cm/s, and the challenge is to determine the displacement at t=5s and x=30cm. Participants suggest starting by expressing y as a function of both x and t, using the wave's speed to adjust the position accordingly. The correct approach involves substituting x=-20cm into the original function to find the displacement at the desired point. Ultimately, the mathematical representation of the wave's movement is confirmed to be y(x,t)=f(x-vt).
Potatochip911
The shape of the wave on the string at t=0 is:
y=(2x)/(x^2+50)
The waveform is moving in the +x direction at a propagating speed of 10cm/s. Find the displacement of the string in cm when t=5s and x=30cm
∂^(2)y/∂x^(2)=(1/v^2)*∂^(2)y/∂t^(2)[/B]
I'm completely lost as to how to solve this, I wanted to try and integrate the function to undo the partial derivative but the function they gave was for when t=0 so all the t variables will disappear and I won't be integrating the right function.
I suspect you are over-thinking things.
Start by writing down y(x,t). You are given enough information to do that directly.
(Actually - you start by drawing a sketch of y(x,t=0)... that can help.)
Likes mfb
Okay I managed to get the answer by plugging in x=-20cm into the y=2x/(x^2+50) since the wave is traveling at 10cm/s in 5 seconds x=-20cm will be the spot at 30cm. I never did figure out how to write it down as y(x,t) though, am I supposed to use the general formula y(x,t)=h(x+-vt)?
That's correct.
Given y(x, t=0)=f(x) then the same shape traveling in the +x direction with speed v is given by: $$y(x,t)= f ( x-vt)$$ ... a negative speed would, therefore, indicate travel in the -x direction.
Eg. If ##y( x,0)=A\sin kx##, then $$y ( x, t)=A\sin k ( x-vt) $$
This is mathematically identical to what you did.
