Finding Electric Field from an insulating sphere
To find the electric field from an insulating sphere with a uniform charge density, first calculate the total charge using the formula Q = D * (4/3)πr^3. For points outside the sphere, the electric field can be determined using E = Q/(4πεr^2), while for points inside the sphere, E can be calculated using E = (1/(4πε)) * (Qr/r^3). The user expressed confusion over which equations to apply and requested a step-by-step guide for solving the problems. Understanding the symmetry of the charge distribution and the appropriate equations is crucial for solving these electric field calculations effectively.
DrKARMA
An insulating sphere with a radius of (3.3E-2) m has a uniform charge density of (6.74E-6) C/m^3 throughout its volume.
(1)Find the magnitude of the electric field at a point (5.7E-2) m from the center of the sphere.
(2) Find the magnitude of the electric field at the surface of the sphere
(3) find the magnitude of the electric field at a point (2E-2) m from the center of the sphere.
Thanks!
Relevant Equations:
Volume of sphere:4/3(pi)r^3
(D) Charge Density=Charge/volume
[Attempt]
I tried to find Q (charge) using D=Q/(4/3(pi)r^3)
Now I am Lost. There are many Electrical Field Equations. I tried plugging into EA=Q/ε but it did not work. I also tried E=q/((4/3(pi)r^2)r^3)
Please help me solve this. Can I see a step by step guide?
Thank you
Thanks!Relevant Equations:
[Attempt]
Thank you
According to the Forum rules, you need to show some attempt for the solution.
What are those many electrical field equations? Which do you think of them relevant?
ehild
There is a nice little "trick" one can use for the first two questions - it's a fact about the electric field of a uniformly charged sphere that will surely be mentioned in your textbook.
There is another useful tool for finding the electric field of charge distributions that are symmetric. This tool will make this problem even easier.
You're close - you just need to know which tools to use and when. Skim over your text and try to understand the underlying concepts and when you can apply different methods of finding electric fields because "there are many electrical field equations" as you said.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
