Finding force, distance, time on a threadmill
  • Thread starter Thread starter Outblaze
    Force Time
To measure force, distance, and time on a treadmill without using machine data, one can use basic tools like meter sticks, scales, and stopwatches. The force is primarily the body weight, while calculating distance can involve multiplying the average leg distance by the number of steps taken. Additional considerations include measuring energy lost through sweat, radiation, and convection, as well as total food energy used during the workout. The energy stored as excess body heat dissipates as the body cools down. The discussion highlights the complexity of accurately measuring these variables and the need for clarity in calculations.
Outblaze
Hello:
I'm trying to find "good" measurement for force, distance and time for a treadmill. I'm assuming the force will simply be the "weight" of my body but the distance..the distance is a different issue altogether.
Since we're contrained in not using the data from the machine, I must use simple devices in my disposal i.e. metre sticks, bathroom scales, stop-watches, etc.
How would I calculate good "distances" assuming I'm not setting the treadmill on an incline (that is, if I don't "have" to set it on an incline).
Can I just calculate the average distance between my legs and multiply that by the number of steps I take?
I must also calculate...
1). Energy conducted away by vaporizing sweat.
2).Energy that has been radiated away by my body during the workout.
3).heat energy stored in excess body temperature.
4). Amount of heat energy lost by convection
5). total food energy used
6). heat energy created during the work-out.
Also, what happens to the energy stored as excess body heat as my body cools down to normal temperature?
Any help would be appreciated. Thanks.
wow, you just can't get an answer out of anyone...
The "weight" issue also worries me because of the fact that it is perpendicular in relation to the distance I'm travelling. But what other force? The force of my legs? Would that mean I have to consider the weight of the leg itself?
energy conducted away by vaporizing sweat...hmm, I would say i should take an initial body weight and final body weight. Difference would give me the amount of heat perspired out of me and that would get me...
the third question seems to be a derivative of the preceeding one...energy radiated away, simply a changing of words?!
total food energy used: get meself the efficiency of leg muscles, but what would output and input be? Should I eat something prior at hand and use that as the "food" I'm tring to burn away?
I'm lost..too many questions.
It seems I have broken the rules in posting a thread in many areas. I dearly apologize for my mistake and I promise never for that to happen again.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
