Finding force(N) wood has against the bullet
  • Thread starter Thread starter Crusaderking1
    Bullet Wood
The discussion revolves around calculating the force exerted by a block of wood on a bullet that penetrates it. The bullet, weighing 1.80 g and traveling at 320 m/s, penetrates the wood to a depth of 0.140 m, leading to an acceleration of -365714.29 m/s². The calculated force is approximately 658 N, considering the opposite direction of forces between the bullet and wood. An alternative method suggested involves using the work-energy principle, where the force can be derived from the kinetic energy lost by the bullet divided by the distance penetrated. The conversation emphasizes the importance of significant figures in the final answer.
Crusaderking1
22.0-caliber rifle bullet of mass 1.80 g, traveling at 320 m/s strikes a block of soft wood, which it penetrates to a depth of 0.140 m. The block of wood is clamped in place and doesn't move. Assume a constant retarding force.
What force, in Newtons, does the wood exert on the bullet?
Long story short, acceleration is -365714.29 m/s^2
Is it really as simple as .0018*-365714.29 = -658.29 N ? Or maybe 658.29 N since the force of the wood on the bullet is opposite of the bullet on the wood?
Since Fnet = ma
Since Fnet = ma
It is that simple [I hope you a value is correct; I haven't checked]
The question referred to a retarding force, so easiest just to answer "The retarding force is 658N" watch the significant figures in your final answer - you use all the figures i your calculations]
Since Fnet = ma
You might find it easier to use energy: the work done by the wood on the bullet is equal to the loss of kinetic energy. So:
F = KE/d
AM
Thanks.
F = KE/d
AM
Never thought about that! thanks, that would make it easier.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
