Finding general expression for probability current.
David Silva
The conservation of probability says:
$$\partial_t J^{0} + \partial{i}J^{i} = 0$$
Use the Schrodinger equation to obtain$$ J^{i} (\vec r)$$.
I have no idea where to start this kind of problem because the notation makes no sense to me. I would appreciate a hint or nudge in the correct direction.
What about the notation confuses you?
What do those partials mean? I am not used to seeing them this way? Also would I be using the general SE eq or the radial one since we are in r?
Typically ##x^0 = t##, ##x^1 = x##, ##x^2 = y##, and ##x^3 = z##, so ##\partial_1## would mean ##\partial_x##. The repeated index ##i## implies a summation from ##i=1## to ##i=3##.
You have ##J^\mu = (\rho,J_x, J_y, J_z)##, so in more traditional notation, conservation of probability is
$$\frac{\partial \rho}{\partial t} + \nabla \cdot \vec{j} = 0$$ where ##\vec{j} = (J_x, J_y, J_z)##.
Thanks, I will look at this later today and see if it helps!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
