Finding Initial Velocity from Rate, Distance, and Time
bhoover05
Hi guys! We started integral word problems today. I am very confused and could use some help with the following;
A particle is moving along a straight line accelerating at a constant rate of 5 m/s^2. Find the initial velocity if the particle moves 60m in the first 4 seconds.
Now, I have been able to do problems similar to these in the past, however without having an equation to start off with, I am confused to where I even begin.
t=4s
distance=60m
accelerating= 5 m/s^2
initial velocity=?
Can you start by writing an equation that expresses the velocity as a function of t? Call the initial velocity v_0 for now, since you don't know its value.
Velocity is the time derivative of distance and acceleration is the time derivative of velocity. So, integrate the acceleration once with respect to time (and don't forget the beloved constant of integration) to get an expression for velocity and integrate velocity to get distance. That should give you enough to solve the problem.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
