Finding J=0 Momentum States in Spin 1/2 Particle System
  • Thread starter Thread starter CrusaderSean
    Momentum Qm
CrusaderSean
I have a general question on finding momentum states
Let's say I have two spin 1/2 particles, so
J=S_1+S_2
and |J| ranges from |S_1 + S_2| to |S_1 - S_2|
in this case J=1 is triplet and J=0 is singlet.
Now how do you find the J=0 state? I know that
|j=0,m_j=0>=\frac{1}{\sqrt{2}}(\uparrow_1 \downarrow_2 - \downarrow_1 \uparrow_2)
but how do you get this in the first place? Is it pretty much trial and error and then use operator to generate rest of the states for that particular J? Or is there an algorithm for finding state |j,m_j=j>?
Well, it's all about reading & understanding Clebsch-Gordan theorem & coefficients correctly. Technically
|j,m\rangle =\sum_{m_{1},m_{2}} \langle j_{1},m_{1},j_{2},m_{2}|j,m\rangle |j_{1},m_{1},j_{2},m_{2} \rangle
The coefficients are tabulated, also, you know that j=0 and m=0.
Daniel.
If you don't have a CG table, you can generate the spin estates.
First form J_11=\up\up. Then use the lowering operator to form the three J=1 states. J_00 will be orthogonal to J_10.
I see. We never really went over CG table so I had to guess the first form and generate rest of the spin (or orbital angular momentum) states. Thanks for the clarification.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
