What is the purpose of the summation and brackets in this limit finding problem?
In summary, the conversation discusses a question with a confusing solution and the attempt to understand it using various methods. The question involves finding the convergence of a series using the ratio test and the solution involves using the Cauchy Condensation Test. The conversation also includes a discussion about a mistake in the solution and potential alternate methods for solving the problem.
unscientific
1,734
I have attached the question, along with the solution in the picture attached. This is one of the few questions I have encountered that I completely have no idea what the solution is trying to do...
It's like they do not make any sense at all!
Confused by
1. The summation on the right - i have no idea what is the purpose of it
2. The terms inside the brackets are also rather weird in terms of Mk-1 or Mk. The summation on the left - it starts from k = 2, 3, ... which doesn't even match the terms in the brackets!
I tried finding the d' Alembert's ratio but it gave me nonsensical answer of as long as x < 0 the series converges which is not true. If you compare the series to 1/n, the series diverges for x > -1
Will appreciate it if anyone can help.
No attachment.
Curious3141 said:
No attachment.
****, thanks for spotting my mistake man. Here's the attachment!
help??
unscientific said:
Confused by
unscientific said:
help??
That solution is rather difficult to understand.
I'll work on understanding it, then attempt to explain it.
Er if you've learned the ratio test, it would help you a lot here. Simply calculate :
lim n->∞ |an+1/an|
This will tell you whether your series is absolutely convergent, divergent or the test simply fails and you have to employ another test like the integral test or the alternating series test to find your answer. Also if you use this like so :
lim n->∞ |an+1/an| < 1
You can also determine for what values of x the series converges for as well as things like the radius of convergence.
Hope this helps.
bump...help anyone? I'm left with this last question for this chapter!
p = lim ( n → ∞) [ (ln n+1)/(ln n) ]x < 1
Then i tried to 'ln' both sides, which brings me:
x * ln [ ln(n+1) ] < 0
Which brings me a nonsensical answer of x < 0 which is not true, using a comparison test with 1/n .
I'm guessing you aren't allowed to use the Cauchy Condensation Test, right? Here is a wikipedia link: http://en.wikipedia.org/wiki/Cauchy_condensation_test
Basically, to me, it looks like the answer in the book is "proving" the condensation test for this one special case. I don't think you will get anywhere just doing a straight ratio test.
It wasn't even written anywhere in the book! Thanks man, i'll have a go at the link.
unscientific,
I don't know if you're still interested, but I do understand the argument given in the link you gave.
First, look at the values of Mk, for several value of k.
k=0: M0 = 2, since ln(2) ≈ 0.693 and ln(1) = 0 .
k=1: M1 = 3, since ln(3) ≈ 1.099 and ln(2) ≈ 0.693 .
k=2: M2 = 8, since ln(8) ≈ 2.079 and ln(7) ≈ 1.946 .
k=3: M3 = 21 .
k=4: M4 = 55 .
k=5: M4 = 149 .
Looking at the nested summation:
[itex]\displaystyle \large S_1=\sum_{k=1}^{\infty} \left(\sum_{r_k=1+M_{k-1}}^{M_k}\frac{1}{\left(\ln(M_k)\right)^X} \right)[/itex]​
We see that when k = 1, r1 goes from 3, to 3:
[itex]\displaystyle \frac{1}{\ln(M_1)}=\frac{1}{\ln(3)}<\frac{1}{\ln(n)}\,,[/itex] for n=2 .​
When k = 2, r2 goes from 4, to 8:
[itex]\displaystyle \frac{1}{\ln(M_2)}=\frac{1}{\ln(8)}<\frac{1}{\ln(n)}\,,[/itex] for n=3,...,7 .​
When k = 3, r3 goes from 9, to 21:
[itex]\displaystyle \frac{1}{\ln(M_3)}=\frac{1}{\ln(21)}<\frac{1}{\ln(n)}\,,[/itex] for n=8,...,20 .​
etc.
There is an error in the last expression for S1. Mk - Mk-1 is only approximately equal to (1 - e-1)Mk, but they are equal in the limit k→∞ . So the final result is valid.
There is a somewhat more straight forward way to achieve the desired result, using a modified version of this method.
SammyS said:
unscientific,
k=3: M3 = 21 .
k=4: M4 = 55 .
k=5: M4 = 149 .
etc.There is an error in the last expression for S1. Mk - Mk-1 is only approximately equal to (1 - e-1)Mk, but they are equal in the limit k→∞ . So the final result is valid.
First of all, thank you for posting your solution. I have read everything and I understand every step, but i am still lost.
I don't see how this answers the question and the purpose of this summation eludes me.. In short, I understand the steps, but I don't see how this is even related to the question at all
The only thing i see is that this summation does the job of summating from k = 1 to k = ∞. But how did they even conceive of this in the first place?!
The only thing i see is that this summation does the job of summing from k = 1 to k = ∞. But how did they even conceive of this in the first place?!
S1 < S.
The ratio test for S1 shows that S1 diverges, for X considered here, i.e. X ≥ 1, which corresponds to x ≤ -1 .
How did they come up with this? I don't know off hand, but it's basically regrouping the
terms of the sum. A similar, but simpler, process can be used to show that [itex]\displaystyle \sum_{n=1}^{\infty}\frac{1}{n}[/itex] diverges.
SammyS said:
S1 < S.
Thank you, I now see how this solves to the question! This is one of the times when i look at the solution and get intrigued by how the person even came up with this..
I figured this must be the thought process of the author:
1. He first had the idea in mind to find a series S1 < S
2. He saw that every term in the series gets smaller and smaller and sought to find a series that used the grouping method.
2. Next he fiddled here and there and finally came up with the governing equation: ln(Mk) > k
3. Then he tried evaluating certain values of k and tried to match the number of terms for each value of k, like for example behind ln 8 there's ln 3, ln 4, ... ln 7. So the summation would be from Mk-1 + 1 to Mk.
4. Then by ratio test, Voilà!
What puzzles me still, is how he came up with ln Mk > k ..
It looks to me as if the person was relating the S sum to the sum [itex]\displaystyle \sum\frac{1}{n}\,,[/itex] so he based S1 on Ʃ(1/n).
Looking at 1/ln(Mk) for several values of k appears to confirm this.
k=1: [itex]\displaystyle \frac{1}{\ln(M_k)}=\frac{1}{\ln(3)}\approx\frac{1}{1.099}<\frac{1}{1}=\frac{1}{k}[/itex]
k=2: [itex]\displaystyle \frac{1}{\ln(M_k)}=\frac{1}{\ln(8)}\approx\frac{1}{2.079}<\frac{1}{2}=\frac{1}{k}[/itex]
k=3: [itex]\displaystyle \frac{1}{\ln(M_k)}=\frac{1}{\ln(21)}\approx\frac{1}{3.045}<\frac{1}{3}=\frac{1}{k}[/itex]
k=4: [itex]\displaystyle \frac{1}{\ln(M_k)}=\frac{1}{\ln(55)}\approx\frac{1}{4.007}<\frac{1}{4}=\frac{1}{k}[/itex]
k=5: [itex]\displaystyle \frac{1}{\ln(M_k)}=\frac{1}{\ln(149)}\approx\frac{1}{5.003}<\frac{1}{5}=\frac{1}{k}[/itex]
k=6: [itex]\displaystyle \frac{1}{\ln(M_k)}=\frac{1}{\ln(404)}\approx\frac{1}{6.0014}<\frac{1}{6}=\frac{1}{k}[/itex]
k=7: [itex]\displaystyle \frac{1}{\ln(M_k)}=\frac{1}{\ln(1097)}\approx\frac{1}{7.0003}<\frac{1}{7}=\frac{1}{k}[/itex]
k=8: [itex]\displaystyle \frac{1}{\ln(M_k)}=\frac{1}{\ln(2981)}\approx\frac{1}{8.00001}<\frac{1}{8}=\frac{1}{k}[/itex]​
As you can see, as k increases, ln(Mk) tends to get closer and closer to integer values.
I see, thanks! I will try to think harder next time :)
I doubt that this was a very easy solution to come up with.
It certainly isn't all that easy to understand --- not very transparent.
I'll try to get around to showing what I think is a somewhat clearer soliution in the next day or two.
The series, [itex]\displaystyle S=\sum_{n=2}^{\infty}\frac{1}{\left(\ln(n)\right)^R}\,,[/itex] can be thought of as a Left Riemann Sum for the improper integral [itex]\displaystyle \int_{2}^{\infty}\frac{1}{\left(\ln(x)\right)^R}\,dx\ .[/itex] Since the function, [itex]\displaystyle f(x)=\frac{1}{\left(\ln(x)\right)^R}[/itex] is monotonic decreasing, S is an upper bound for this integral.
If we construct a Right Riemann Sum, S2 for this integral, then S2 is a lower bound & we have that [itex]\displaystyle S \ge\int_{2}^{\infty}f(x)\,dx\ge S_2\ .[/itex] If S2 does not converge for some value of R, then S does not converge for that same value of R.
Construction of a Right Riemann Sum, S2:
[itex]\displaystyle \text{Let }\ x_0=x_1=e\quad\to\quad f(x_1)=1/\left(\ln(e)\right)^R=1[/itex]
In general, for k ≥ 1:
[itex]\displaystyle \text{Let }\ x_k=e^k\quad\to\quad f(x_k)=1/\left(\ln(e^k)\right)^R=1/k^R\ \ \text{ and }\ \ \left(\Delta x\right)_k=e^k-e^{k-1}[/itex]
This gives the following for S.
[itex]\displaystyle S_2=\sum_{k=1}^{\infty}f(x_k) \left(\Delta x\right)_k=(e-2)+\sum_{k=2}^{\infty}\frac{e^k-e^{k-1}}{k^R}=(e-2)+\sum_{k=2}^{\infty}\frac{e^{k-1}(e-1)}{k^R}[/itex]​
Applying the ratio test gives:
[itex]\displaystyle \frac{\displaystyle \ \ \frac{e^{(k+1)-1}(e-1)}{(k+1)^R}\ \ }{\ \ \displaystyle \frac{e^{k-1}(e-1)}{k^R}\ \ }=e\left(\frac{k}{k+1}\right)^R\quad\to \ \ e\ \ \ \text{ as }\ k\to\infty[/itex]
Thus S2 diverges and so does S.
hmm that looks better than the previous solution. But why do you choose
xk = ek , where Δx = ek - ek-1
why can't you simply choose a simple one such that Δx = 1? Then it would resemble the previous S more..
This may break the previous chain of thought, but I wanted to add a warning relating to SammyS's first proof using regrouping of terms. Generally, it is unsafe to use this technique. There exist examples of series where the order of summation may matter so that the limit of the series may not be well defined. There is a small section in Rudin that explains this phenomenon.
Hi "who". I think that only applies to series with both positive and negative terms which are not absolutely convergent. For a series like this with all positive terms I think that if it fails to converge for one ordering of the terms then it will fail for all.
Yes this is what I thought too Robert. The proof is so simple when using that theorem, that to be honest, I think it's probably easier to do it this way even if you had to prove the Cauchy Condensation Theorem first (for the [itex]2^n[/itex] case).
Yes, in those scenarios it is safe. I was just putting it out there so that one might not get the notion that one can regroup terms in general. But absolute convergence is a must (in fact, that is the definition of absolute convergence).
1. What is the purpose of finding limits of summation?
Finding limits of summation allows us to determine the range of values that the summation should be calculated over. This helps us to accurately calculate and analyze the sum of a series of numbers.
2. How do I find the lower limit of summation?
The lower limit of summation is typically denoted by the variable below the summation sign. It represents the first value in the series that should be included in the sum.
3. How do I find the upper limit of summation?
The upper limit of summation is typically denoted by the variable above the summation sign. It represents the last value in the series that should be included in the sum.
4. What happens if I exceed the upper limit of summation?
If you exceed the upper limit of summation, the calculation will not be accurate as it will include numbers that should not be part of the series. Make sure to carefully check your limits before calculating the sum.
5. Can the limits of summation be negative?
Yes, the limits of summation can be negative. This is often the case when dealing with series that involve negative numbers or when using the concept of a backwards summation.
  • General Math
