Finding Magnetic Force on a Moving Electron
To find the magnetic force on a moving electron, the correct approach involves using the vector equation F = q(v x B), where v is the velocity vector and B is the magnetic field vector. The right-hand rule is essential for determining the direction of the force, which will be perpendicular to both the velocity and magnetic field vectors. The angle phi between the vectors must be identified to calculate the magnitude correctly. Attempting to find forces in the i and j directions separately and multiplying them is incorrect; the cross product must be used instead. Understanding these concepts allows for accurate computation of the magnetic force on the electron.
bbbbbev
Hi. Ok, here's the problem:
An electron that has velocity v = (3.6 106 m/s) i + (3.7 106 m/s) j moves through a magnetic field B = (0.03 T) i - (0.15 T) j.
(a) Find the force on the electron.
I know how to find the force from scalar numbers (using the equation F_mag = q x v x Bsin(phi)), but I can't figure out how to do it with vectors. I know that the answer is going to be in the "k" direction, but I don't understand how to get a k from an i and a j, and I can't find how to do it in the book or on any website.
I tried finding the force in the i direction and then the force in the j direction and doing vector addition, but that didn't work because the resultant vector is not in the k direction. I guess the real problem is that I don't know how to add j and i vectors to get a k vector. Could someone please help? Thanks alot! Beverly
Howdy Beverly. I'm sure you have seen written somewhere the magnetic force in terms of vector as
F_{mag} = q(\vec{v} \times \vec{B})
This means that the vector force has a magnitude given by vBsinO (like you did) and a direction given by the right hand rule.
Learn about the right hand rule here.
Oh, thanks. I think I get it. Can I just find force in the i direction and then find force in the j direction and then multiply them together to get the magnitude in the k direction? I tried doing this:
F_i = q x v_i x B_i
F_i = (1.6E-19C)(3.6e6m/s)(0.03T)
F_i = 1.728E-14 N
F_j = q x v_j x B_j
F_j = (1.6E-19C)(3.7e6m/s)(-0.15T)
F_j = -8.88E-14 N
Then I multiplied F_i x F_j to get F_k, but that answer was incorrect. Am I understanding the right hand rule thing wrong??
Thanks for your help,
Beverly
bbbbbev,
No, you can't do it that way. Go back to the equation you started with:
F =qvBsin(phi) where phi is the angle between the directions of v and B.
Can you figure out what phi is?
The scalar force IS the magnitude of the vector force. The right hand rule only adds to it by telling you the direction of the force based on the directions of the vectors v and B.
Thanks! I got it. I figured out phi and just used that equation. Thanks guys.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
