Finding Magnitude of Unkown Force on Rough Horizontal Surface
A block of mass 100g is in limiting equilibrium on a rough horizontal surface with a rope inclined at 20° and a tension of 0.5N. The coefficient of static friction was calculated to be approximately 0.58. For the object to accelerate at 1.5m/s², the required tension was found to be 0.63N, which raised concerns about its proximity to the limiting equilibrium force. Discussions highlighted the importance of using algebraic methods for clarity and accuracy in calculations. The conversation also clarified the relationship between static and kinetic friction, emphasizing that problems typically assume static friction unless otherwise specified.
FaraDazed
A block of mass 100g is at rest on a rough horizontal plane. It has a massless rope attached to one end inclined at 20° above the horizontal. When the tension in the string is 0.5N the object is found to be in limiting equilibrium.
Part A: Find the coeffecient of static friction between the object and the plane.
Part B: What would the tension in the string have to be to make the object accelerate at 1.5m/s^2.
Fnet=ma
R=mg (R is the normal reaction force)
For clarification, F_f is the frictional force. and P is the unkown foce in part B.
Part A:
<br /> 0.5cos20=0.47\\<br /> 0.5sin20=0.17\\<br /> mg=R+0.17\\<br /> 0.98=R+0.17\\<br /> ∴ R=0.98-0.17=0.81\\<br /> <br /> F_f=0.5cos20 (because \space the \space force \space applied\space by\space the\space string\space to\space the\space horizontal \space must \space equal \space the \space frictional \space force)\\<br /> ∴F_f=0.47\\<br /> μR=0.47\\<br /> μ0.81=0.47\\<br /> ∴ μ \frac{0.47}{0.81}=0.58 \\<br />
Part B:
<br /> R+Psin20=mg \\<br /> R+Psin20=0.98 \\<br /> ∴ R=0.98-0.34P \\<br /> \\<br /> Pcos20-F_f=ma\\<br /> Pcos20-μR=0.15\\<br /> ∴0.94P=0.15+0.58R\\<br /> 0.94P=0.15+0.58(0.98-0.34P)\\<br /> 0.94P=0.15+0.57-0.2P\\<br /> 1.14P=0.15+0.57\\<br /> 1.14P=0.72\\<br /> ∴ P=\frac{0.72}{1.14}=0.63N \\<br />
My main issue is if I have done it right because the answer to Part B seems rather low compared to the force when it is in limiting equilibrium i.e. only 0.13N more.
Any help/pointers is appreciated.
Hi Faradazed,
As a matter of technique, it's a really good idea to do most of the work purely in algebra, using symbols even for values that are known. Then plug all the numbers in at the end. It's much easier to spot mistakes, and less prone to silly errors.
FaraDazed said:
Ff =0.81
I assume you meant Ff = .5 cos 20
Part B:
The question is not quite kosher here. It should tell you the dynamic friction.
You know it will be roughly .15N more, since that would be the force to accelerate it that fast with no gravity or friction. You may be surprised that it's a bit less than .15. That's because some of the extra force goes into reducing the normal force, and hence the friction. That 'frees up' some of the 0.5N to produce acceleration. In general, there is an optimal angle at which to drag a load.
Hi, thanks for replying :)
haruspex said:
Hi Faradazed,
Yes it is a habit I need to get out of, my math teacher has commented on it, I am trying to improve upon this :)
Yes I think this was a copying error from my written work to typing it onto the computer
Is that the same as kinetic friction? We have only been taught about static friction so I assume all problems given are meant to act like as if kinetic friction is nonexistent.
I see. Does what I have done (apart from not writing it out in an algebraic way to start with) look OK to you then?
Yes, kinetic is the usual word, sorry.
I would think the default assumption is that it's the same as the static friction. That seems to be what you have to assume here.
Yes, it's fine.
Yes, it's fine.
OK, many thanks :)
