Finding mass of spring from time period.
The discussion focuses on determining the mass of a spring using the time period squared (T^2) graph against the attached block mass (M). The practical handbook provides a formula that includes variables N, n, R, and r, which are not defined, leading to confusion. By setting T=0, the relationship M+(m*/3)=0 is derived, resulting in m*=3 times the x-intercept. The formula's origin is clarified through the concept of the effective mass of the spring, which incorporates its kinetic energy. Understanding this relationship is crucial for accurately calculating the spring's mass in the experimental setup.
amk_dbz
As the title suggests, there is a practical in which we have to find mass of the spring (m*) having a block of mass M attached to bottom, from GRAPH of time period (T)^2 against M.
Here's what the practical handbook says:
T^2= [16{(pi)^2}(R^3)N][M+(m*/3)] / [(r^4)n]
there is no reference to what is N,n,R,r
What they do next is to plug in T=0
therefore, M+(m*/3)=0
=> m*/3=-M
Considering magnitude, m*=3(x intercept)
The last part makes some sense but, where does the formula come from?
Thank you! (Sorry for being messy)
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
