Finding Power in watt with a real battery
To calculate the power dissipated by a 2.4-ohm resistor connected to a 1.5V battery with an internal resistance of 10 ohms, the correct approach involves using the formula P = I^2 * R. The current (I) can be determined using Ohm's law, I = V / (R_total), where R_total is the sum of the resistor and the battery's internal resistance. The user is struggling to find the correct answer despite knowing the relevant equations. A step-by-step calculation is requested to clarify the process. Understanding the total resistance in the circuit is crucial for accurate power dissipation calculations.
dmsgo89
calculate the power dissipated by a resistor R connected to the battery when R = 2.4 ohm.
I=V/R
I found A of battery that given and put R value given to find P, however I cannot get a right answer.
What did I wrong?
http://session.masteringphysics.com/problemAsset/1021126/12/jfk.Figure.23.P47.new.jpg
The images shows that the battery has 10 ohm and 1.5V.
It is due tonight and I am lost :( please help!
oh and I know P=I*V=V^2/R=RI^2
Please show us exactly what you have calculated and why you calculated it.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
