Finding radius of convergence of series ?
SMA_01
How would I find the radius of convergence of this series?
f(x)=10/(1-3x)2 is represented as a power series f(x)=\sum from n=0 to \infty CnXn
Okay so I tried deriving, using d/dx(1/1-3x)=3/(1-3x)2 and ended up with \sum (3x)n and I derived this series to get \sum 3nnXn-1
I'm lost where to go from here or if I even did it right...how would I find the radius of convergence?
The standard way to find the radius of convergence of a power series is to use the "ratio test": the series \sum a_n converges if \lim_{n\to\infty} \left|\frac{a_{n+1}}{a_n}\right|< 1<br /> Here, a_n= 3^nnx^{n-1} and a_{n+1}= 3^{n+1}(n+1)x^n so that the ratio is <br /> \left|\frac{a_{n+1}}{a_n}\right|= \frac{3^{n+1}(n+1)|x|^n}{3^nn|x|^{n-1}}= 3\frac{n+1}{n}|x|<br /> 1?<br /> What is the limit of that as x goes to infinity? For what values of x is that less than 1?<br /> <br /> One can, however, show that a power series will converge as long as there is "no reason not to"! The fraction 10/(1- 3x)^2 only has a problem when the denominator is 0. That is, when 1- 3x= 0 or x= 1/3. There is "no reason not to converge" all the way from 0 to 1/3.
That looks pretty good. I don't think you've been careful enough to quite get the series exactly correct. But that's not going to change the radius of convergence. Now use a ratio test to find the interval of convergence.
Thanks a lot! I didn't know I could use the ratio test form there.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
