Finding RMS Speed of Gas Atoms: Ideal Gas
The discussion focuses on calculating the root mean square (RMS) speed of gas atoms in an ideal gas scenario with a density of 2.4 kg/m³, pressure of 2.0 × 105 Pa, and temperature of 300 K. The relevant equation used is p = (1/3) * (N/V) * v2, where N is the total number of atoms. Participants clarify that the density can be expressed as mN/V, linking it to the RMS speed calculation without needing to specify the number of atoms explicitly, as the problem is framed for one atom.
  • Understanding of ideal gas laws
  • Familiarity with the concept of root mean square speed
  • Knowledge of density and its relation to mass and volume
  • Basic algebra for manipulating equations
  • Study the derivation of the RMS speed formula for ideal gases
  • Learn about the relationship between pressure, density, and temperature in gas laws
  • Explore the concept of Avogadro's number and its application in gas calculations
  • Investigate the differences between moles and individual atoms in gas calculations
Students studying thermodynamics, physics enthusiasts, and anyone involved in gas law applications or calculations related to ideal gases.
AllenHe
The ideal gas has a density of 2.4 kgm–3 at a pressure of 2.0 × 105 Pa and a
temperature of 300 K.Find the root mean square speed of the gas atoms.
p=(1/3)*(Nm/V)*v(squared)
I tried to make v(squared) the subject, but N(the number of atoms) is not given, and when I looked at the answer, it made v(squared) the subject, and omitted N. I don's understand why do they have to omit N, is it because we are suppose to find the speed for one atom?
Sorry for my bad English.
Well, N/V is the number of particles per unit of volume. If you multiply this by m, the mass per particle, you get the mass per unit volume. What's another name for that?
Thanks
Oh, I get it, so you mean the density is mN/v, right?
Yes, he means that in,
P= mnvrms2/3V
Density is mn/V
m=molar mass
n=number of moles
But you have written N=avogadro's number
m=mass of one molecule ?
Are you giving this formula for 1 mole of gas ?
Yes, that is exactly what I meant :)
P= mnvrms2/3V
Density is mn/V
m=molar mass
n=number of moles
The OP explicitly stated that N was the total number of atoms. So this problem isn't doing anything with moles.
