Finding static force and kinetic force
To find the coefficient of kinetic friction for a 4.00 kg block pushed along the ceiling with an 85 N force at a 55-degree angle, it is essential to analyze the forces acting on the block. A free body diagram should be drawn to separate the forces into horizontal and vertical components. The equation F = ma can be applied in both directions to determine the net force and acceleration. The lack of a qualified teacher has hindered the understanding of these concepts, making it challenging to solve the problem. Assistance in applying these principles is needed to find the solution.
tallbus1
A 4.00 kg block is pushed along the ceiling with aconstant applied force of 85 N that acts at an angle of 55 degrees with the horizontal. The block accelerates to the right at 6.00 m/s2. Determine the coefficient of kinetic force between the block and cieling
No idea!
Again, no idea
Our physics class has been without a degreed teacher since the beggining of the school year and there are serious holes in our classes learning yet we are expected to be learning at the pace of other classes, while this is hardly an excuse I could use some help on this problem.
draw a free body diagram.
split all forces in horizontal and vertical components, you have F = ma in both directions.
