Finding Surface area using Newton's Law
Newton's Law of Cooling describes the rate at which an object cools based on its temperature relative to its surroundings. The formula involves the heat conduction coefficient (k), surface area (A), and the temperature difference between the object (T) and the surrounding environment (Ts). The discussion highlights practical applications, including using the law to determine the time of death and cooling food. A notable point is that by analyzing the cooling process, one can estimate the surface area of an object, as the constant k can be expressed as kA/C, where C is the heat capacity. The conversation also touches on heat convection, emphasizing the importance of understanding fluid dynamics and the challenges in accurately calculating the convection coefficient (h). This coefficient is crucial for determining heat exchange and can be derived from experimental correlations or complex equations like the Navier-Stokes equations.
maccaman
As part of a homework assignment, I am required to research Newton's Law of Cooling and evaluate it with three practical examples. One must be time of death. So far i have created a time of death example, and used an example to cool food. However the last one i heard someone say is that you could use Newton's Law of cooling to find the surface area of the object that is under question. I have also read that this has something to do with the value of the constant k. If anyone could help me it would be greatly appreciated.
I don't know that much about this subject and I do not have a book at hand for formulas, but maybe this will help:
Newtons law of cooling is something like: dQ/dt=-kA(T-Ts) with k the "heat conduction coefficiënt" or something, A the surface area, T the temperature of the body in question and Ts the temperature of the surrounding.
If you use: dQ=CdT (C the heat capacity) you get: dT/dt=(-kA/C)(T-Ts) with the (only initially! correct) solution: T(t)=Ts+(T0-Ts)e^-(kA/C)t by applying the appropriate boundary conditions.
So the 'k' in your other question (https://www.physicsforums.com/showthread.php?t=38534) is something like kA/C. So by studying the cooling of an object you can get information about it's surface area by using the formulas above
I know the solution of the differential equation above is only an approximate solution. But maybe the equation in your other post itself isn't much more than that. Anybody care to help some more...?!
Of course. Do you ever have heard to talk about the use of fins like heat dissipators?. If q=A*h*(T-Ts) where:
A=surface area of convection;
h=convection coefficient ( I advise you to name it as I have done).
T=surface temperature;
Ts=surroundings temperature
q=thermal power exchanged,
Thus, if q, T, Ts and h are known, A could be calculated. You should know Newton's Law talk to us of another mechanism of heat transfer: the convection. Heat Convection is a function of the area of exchange. To completely understand the convection mechanism you must know something about Fluid Dynamics. The constant of convection h is a very hard variable of computing. If you advance in the future in this topic you will fight a lot in order to obtain an accurate value of h. Usually engineers calculate it with correlations that emphazises in one experiment in concrete. But other brave folks calculate h solving the Navier Stokes equations over the external flow.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
