Finding the angel between two vectors
  • Thread starter Thread starter ssb
    Vectors
8 replies · 16K views · last reply
ssb
I have two vectors
Vector A and B
Axi = -3
Ayj = 5.4
Bxi = 1.3
Byj = -3.9
I want the angle between them so I do the dot product
(-3)(1.3)+(5.4)(-3.9) = -24.96
Therefore the angle between them is
-24.96 = |-24.96|cos(theta)
Arccos(-24.96/24.96) = theta
Arccos(-1) = theta
Theta = pi = 180 degrees.
Is this correct? :confused:
Your calculation for the dot product is correct, however you have used the wrong formula: the formula you need is [tex]\vec{a}\cdot\vec{b}=|\vec{a}||\vec{b}|\cos\theta[/tex]. How do you find the magnitude of a vector? (i.e. [itex]|\vec{a}|[/itex])
Ok so the magnitude of vector a would be
= sqrt(5.4^2 + 3^2)
= (3*sqrt(106))/5
= 6.18
Magnitude of B would be
= sqrt(-3.9^2 + 1.3^2)
= (13*sqrt(10))/10
= 4.11
therefore
-24.96 = abs(4.11) * abs(6.18) cos(theta)
Theta = arccos [(-24.96)/(abs(4.11) * abs(6.18))]
theta = 90 degrees = pi/2 radians
Does this look accurate?
It can't be 90. That would imply the dot product is zero (see the formula mentioned)
I guess I am still confused on the [tex]|\vec{a}||\vec{b}|[/tex] part
this would be finding the magnitudes then multiplying their absolute values together right? The magnitudes are found with pathegoran's theorem correct?
= sqrt(5.4^2 + 3^2)
= (3*sqrt(106))/5
= 6.18
= (13*sqrt(10))/10
= 4.11
therefore
What is the value of [(-24.96)/(abs(4.11) * abs(6.18))]?
its just about -1.
Find the angle between
A = -3i + 5.4j
B = 1.3i - 3.9j
(-3 * 1.3)+(5.4 * -3.9) = -24.96
-24.96 = ab cos(theta)
therefore
theta = arccos (-24.96/sqrt[(2^2+1.3^2)(5.4^2+(-3.9)^2)]
theta = domain error when I try to calculate it.
ssb said:
its just about -1.
A = -3i + 5.4j
B = 1.3i - 3.9j
therefore
Where did you get that "2" in the square root? You should have
sqrt[((-3.9)^2+ 1.3^3)(5.4^2+ (-3.9)^2)].
When you replaced my 2 with a -3.9, did you mean to replace it with a -3?
If this is the case then my questions have been answered!
thanks everybody for helping me with this most basic topic
