Finding the center of mass of a solid hemisphere
The discussion revolves around the incorrect derivation of the center of mass (CoM) for a solid hemisphere, initially approached by considering it as composed of smaller hemispherical shells. The user calculated the mass of these shells but arrived at an incorrect formula for the CoM, yielding a result of Y_cm = R/4, which is disputed. Participants highlight that the mass element should be derived differently, suggesting the use of a thin shell approach with the correct expression for mass, dm = 2πr²dr. The conversation emphasizes the importance of verifying calculations and understanding the geometry involved in the derivation process. Ultimately, the user is encouraged to reassess their method and calculations to identify the source of the error.
Hamiltonian
find the center of mass of a solid hemisphere of radius R.
##Y_{cm} = \frac {1}{M} \int y dm##
for this derivation, I decided to think of the solid hemisphere to be made up of smaller hemispherical shells each of mass ##dm## at their respective center of mass at a distance r/2 from the center of the base of the solid hemisphere.
also, I have taken the center of the base of the solid hemisphere to be the origin. Due to symmetry, I know that the center of mass of the solid hemisphere is along the Y-axis.
I found the mass ##dm## of all the small hemispherical shells
$$dm = \frac {M}{(4/6)\pi R^3} (\frac{4\pi}{3}r^2 dr)$$
substituting ##dm## into $$Y_{cm} = \frac {1}{M} \int \frac {r}{2} dm $$
gives me ##Y_{cm} = R/4## which is wrong.
also, I know this can be done in a slightly easier way if you consider the hemisphere to be made up of solid discs but I thought I'd give this method a go! can someone help point out what exactly I am doing wrong here:)
This doesn't sound right. What do you mean by this?
I have considered the large solid hemisphere to be made up of smaller hemispherical shells whose center of mass we know is at ##r/2## and is of mass ##dm##
View attachment 269250I have considered the large solid hemisphere to be made up of smaller hemispherical shells whose center of mass we know is at ##r/2## and is of mass ##dm##
Why is the CoM of the shell at ##r/2##?
hmm...because you can derive that by breaking the hemispherical shell into rings of mass ##dm## whose CoM lies at their centers and then you end up with $$Y_{cm} = 3R/2\int_0^{\pi/2}cos\theta sin^2\theta d\theta = R/2$$
the origin is at the center of the base of the hemispherical shell and R is the radius of the hemispherical shell.
Likes PeroK
Can you see why that doesn't work?
I thought breaking a solid hemisphere into hemispherical shells was analogous to breaking like a solid disk into smaller rings?
That's not the problem. This is the problem:
$$Y_{cm} = \frac {1}{M} \int \frac {r}{2} dm$$ so this is wrong?
Consider a thin hemisphere of thickness ##dr##, and mass ##dm = 4\pi r^2 \rho dr##. Since the hemisphere is of infinitesimal thickness, its centroid is at ##\frac{r}{2}## in the ##y## direction. The sum of the first moments of mass of all of these tiny hollow hemispheres, which combine to make a solid hemisphere, in the ##y## direction, ##S_y##, will be$$S_y = \int_0^R y dm = 2\pi r^3 \rho dr$$Can you take it from here?
Actually, my apologies, this calculation is correct.
what exactly is wrong in my method?
I think this is not right. It should be ##2\pi r^2 dr## for a shell of radius ##r## and thickness ##dr##.
Likes Hamiltonian
PS I thought it was simpler to integrate disks of radius ##r## and height ##dz##:
$$dm = \rho \pi r^2 dz = \rho \pi (R^2 - z^2)dz$$
And, for the hollow hemisphere I got the integral:
$$R \int_0^{\frac {\pi}{2}}\sin \theta \ \cos \theta \ d\theta$$
what exactly should be ##2\pi r^2 dr##? ##dm##?
also, I am considering the mass per unit volume.
In place of the volume formula you used.
how exactly did you get that?
I got the volume of ##dm## as $$=\frac {4\pi}{6}(r + dr)^3 - \frac {4}{6}\pi r^3$$
$$\approx \frac {4\pi}{3}r^2dr$$
That's definitely not right. I took the surface area times ##dr##. It should come to the same thing.
What do you get when you expand ##(r + dr)^3##?
what exactly is wrong here as we are supposed to get the same answer either way? or is the approximation of ##(dr)^2 = 0## and ##(dr)^3 = 0## wrong?
You have to start challenging your own work. And being able to double-check things for yourself.
PS You can be as skeptical as you like, but you're the one who is asking why you got the wrong answer.
Likes Hamiltonian
