Finding the Chemical Formula and Relative Molecular Mass
In summary, the chemist has a problem with weight percentage of nitrogen in a compound and is wondering if anyone can help him out.
nineteen
68
My chemistry teacher gave me this problem. I tried and tried, but I couldn't figure it out and the deadline is tomorrow. Please help me out here friends.
1. This is the problem :
In a compound which is made of element Y, weight percentage of Y is 72% and N( Nitrogen) is 28%. Also, 3 Y atoms are bonded with 2 Nitrogen atoms. Find the followings...
  1. Chemical formula of the compound.
  2. Relative molecular mass of Y.
are :[/B]
n of molecular formula = Molar mass/ Formula mass of empirical formula
number of moles = mass/Molar mass
(at least I think these are the only equations used.)
[/B]
The things is that, even though I tried I couldn't approach the question... I couldn't find a way to enter and continue doing. Therefore there is nothing like an attempt done to solve the problem. I am sorry if this contradicts with your procedure of this specific template.
Please help me out here.
Isn't the chemical formula more or less given in the problem?
Knowing the mass of N and the its mass percentage in the compound should get you the molecular mass of the compound.
Likes nineteen
If the compound contains 28% of nitrogen, how many grams of nitrogen in 100 grams of the compound? How many moles is that? What is the mass of the element Y present?
Likes nineteen
Hey, thanks for helping out. Like you said, the chemical formula is the one said in the question itself right? It wasn't obvious to me at first, but now I tend to think so too.
Thanks for helping out my friend. By the way, the chemical formula is N2Y3 right?
Yes, that's what you were told.
Likes nineteen
Thank you very much man!
Hey I didn't understand what you said here. Except for the molecular formula thing, what you said here is a bit unclear to me. Can you please explain it further if you don't mind? Thank you very much in advance...
Here's my solution. If there is anything please correct me...
(Mass of N/Total mass) x 100% = 28
Therefore, total mass = 100g
(3 x Mass of Y/100g) x 100% = 72
Mass of Y = 24 g
Chemical formula = Y3N2
The element having a mass of 24 is Mg
Therefore; chemical formula is Mg3N2
R.M.M = (24x3) + (14x2)
= 100
No, that's an incorrect conclusion. I told you to assume mass of the sample to be 100 g as it often simplifies understanding calculations when percentages are involved (but in general is never necessary).
But your final answer is OK.
Likes nineteen
Thank you very much
By the way, why did you say we have to assume? I don't understand. In the question it says there are 2 Nitrogen atoms bonded with 3 Y atoms and so, I selected the mass of mass of nitrogen as 28, and thought that it is the amount of mass in the total sample that when taken as a percentage it gives us 28%. See just like this...
[(14x2)/Total Mass] x 100% = 28 14 is the mass of one Nitrogen
(28/Total Mass) x 100% = 28
(28x100)/28 = Total Mass
So, Total Mass = 100 in grams...
I mean like, why is thinking this way wrong? @Borek
You are just proving that 1=1, which is hardly an interesting and valuable conclusion. You can insert any value for 28 and it will still hold. It also happens this particular compound has a molar mass of 100 g/mol so it looks like 100 g is special here. It is completely accidental and it will not work for other compounds.
Likes nineteen
Ok, got it. Thank you very much!
FAQ: Finding the Chemical Formula and Relative Molecular Mass
1. What is a chemical formula?
A chemical formula is a representation of the elements present in a compound and their respective ratios. It shows the types and numbers of atoms that make up a molecule.
2. How do you determine the chemical formula of a compound?
The chemical formula of a compound can be determined by conducting experiments and analyzing the results. This can include using techniques such as spectroscopy, mass spectrometry, and elemental analysis.
3. What is relative molecular mass?
Relative molecular mass, also known as molecular weight, is the sum of the atomic weights of all the atoms in a molecule. It is expressed in atomic mass units (amu) and is used to compare the masses of different molecules.
4. How do you calculate the relative molecular mass?
The relative molecular mass can be calculated by adding the atomic weights of all the atoms present in a molecule. The atomic weights can be found on the periodic table of elements. For example, the relative molecular mass of water (H2O) would be 2(1.008 amu) + 1(15.999 amu) = 18.015 amu.
5. Why is it important to know the chemical formula and relative molecular mass of a compound?
Knowing the chemical formula and relative molecular mass of a compound is important for various reasons. It helps identify the elements present in a compound and their ratios, which can provide insight into its properties and behavior. It also allows for accurate calculations in chemical reactions and can aid in the production and purification of the compound.
11K
