Finding the coordinates and distance of this drawing
The discussion focuses on calculating the coordinates and distance of point P(s,t) on vector A. The user initially struggles with the distance formula and the assumption that P is the midpoint of vector OA. Clarification is provided that P's position vector is a multiple of vector A, and the slopes of lines OA and BP can be used to find the coordinates of P. The user expresses confusion about the origin of point OA and the correct application of slope calculations. The conversation emphasizes the need to establish relationships between the slopes to solve for P's coordinates and the length of OP.
mr_coffee
Hello everyone, I'm having problems figuring out the distance and the cordinates of the point P(s,t). The directions are in the drawing posted. I'm not sure if i drew the picture right though. I used the distance formula to find the distance between the origin i named <x,y> and the point P(s,t) which is on the vector a = <x1,y1>. But i might have screwed that up too because I assumed its the midpoint of the vector. I don't know how I'm suppose to simplfy |d| in the drawing. Once that's simplified I'm also confused on how that is going to tell me the coordinates of P. Thanks,
http://show.imagehosting.us/show/654150/0/nouser_654/T0_-1_654150.jpg
You didnt't attach it.
Sorry about that, thanks for the info, it is now attached!
P is a point on the vector A, so P's position vector is given as a fraction (or multiple) of the position vector of A. i.e. OP = λ(x1,y1).
If P were the mid-point of OA (which it isn't) then you would have λ = ½.
You can work out the slope of OA (=m, say) using the coords of A and you know that BP is perpindicular to OA, so you can write the slope of BP in terms of m. You can also work out the slope of BP using the coords of P and B. Now solve for λ, and you can then work out the coords of P and the length of OP.
thanks for the reply but I'm lost.
Where is the point OA coming from? by OA do u mean the vector O standing for origin and A for the a vector? So your saying set BP, B is a vector <x2,y2> and P is a point with coords (s,t) = m. Am i allowed to do this? BP = (y2-t)/(x2-s); or are u not talking about m = (y2-y1)/(x2-x1)?
