Finding the Critical Value of IVP: 'Given DE
  • Thread starter Thread starter tylerc1991
    Ivp Value
tylerc1991
This is more theoretical than anything, but let's say that a problem is stated like:
Consider the IVP: 'given DE'; y(0) = y_0
find the value of y_0 that separates the solutions that grow positively from those that grow negatively as t -> infinity.
(1) Is there a name for this particular value of y_0? Is it called the critical value?
(2) is the critical value always found by setting c = 0? (where c is the constant of integration found when solving the IVP)?
Thank you for your help and let me know if I am unclear with anything.
The way I have seen this is:
In a more generalized form in first order (y' = f(x, y)), if there exists a solution that serves as a boundary between two classes of solutions to the differential equation that behave differently, then that solution is called a separatrix. I don't think I have seen a term for the initial value, but it combined with the equation would give you the solution that served as the boundary anyway. Seeing as how picking a different value of x would give a different initial value somewhere along the separatrix, potentially, I think the solution would be more important from a theoretical standpoint.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
