Finding the diameter of a coil.
  • Thread starter Thread starter cds5615
    Coil Diameter
To find the diameter of a coil made from a 1.2-m-long copper wire that generates a 0.60 mT magnetic field with a current of 1.5 A, the correct approach involves using Ampere's law. The formula BL = INμ₀ can be applied to determine the number of turns (N) in the coil. Once N is calculated, dividing the wire length by N provides the circumference of each turn. The diameter can then be derived from the circumference. This method effectively resolves the issue of obtaining a numerical value for the diameter.
cds5615
You have a 1.2-m-long copper wire. You want to make an N-turn current loop that generates a 0.60 mT magnetic field at the center when the current is 1.5 A. You must use the entire wire.
What will be the diameter of your coil?
I tried applying this formula d = sqrt ( (mu*L*I/pi*B)) and keep getting a really small number =0.000021 m
What am I missing here??
What was the original formula? Name of it?
I actually just got it from a classmate, him and his friend were both able to get to the answer from that equation.
I tried using B= mu*(N/L)*I but you don't end up with a numerical value when solving for d. There must be a way to find the answer with another method...
Ahhh I see, well I'll s how you how to do it. Use Ampere's law. BL = IN\mu_0
It will yield the correct answer, and I can see whoever wrote the question planned it very well.
But I am solving for diameter. How can I apply that equation?
Well.. You know everything except for N (number of turns).
Once you've found how many turns you have divide the length of the coil by N. That will clearly give you the circumference of each turn (provided they are uniform).
