Finding the E due to a non-uniform surface charge distribution in 3D
The discussion revolves around calculating the electric field due to a non-uniform surface charge distribution in the yz plane, specifically at the origin. The electric field just to the right of the origin is given as 4.8 × 10^5 N/C, raising questions about the expected field strength to the left of the origin. Participants explore the concept of the electric field from an infinite sheet of charge, which is calculated to be σ/(2ε(naught), resulting in a value significantly lower than the observed field. The discrepancy suggests that additional contributions from nearby charged objects must be considered to explain the observed field strength. The conversation emphasizes the importance of understanding how electric fields distribute and the effects of nearby charges on field measurements.
Shostakovich
Here is the question, which itself is rather confusing.
A nonuniform surface charge lies in the yz plane. At the origin, the surface charge den- sity is 3.5 μC/m^2. Other charged objects are present as well. Just to the right of the origin, the electric field has only an x component of magnitude 4.8 × 10^5 N/C.
What is the x component of the electric field just to the left of the origin? The permittivity of free space is 8.8542 × 10^−12 C2/N · m^2.
Answer in units of N/C
ø=∫E.dA = Q(enclosed)/ε(naught)
σ = Q/A
So i drew the pictures, a 2D surface lying in the yz, with a point x with electric field value 4.8e5 N/C just to the right on the positive axis.
I thought to myself the field will just be negative because its on the opposite side? Nope.
Maybe it's the same? Nope.
I then tried finding the difference, to no avail, and now I'm just stuck.
Is there a better way for me to think about this problem that I'm not seeing, or is it just that obscure?
Hmm. Suppose that "just to the right of the origin" implies that the observer there is so close that he "sees" the surface charge in the yz plane as an infinite sheet of charge with the given charge density. What field strength would he expect to see from it? How does that compare to what he actually observes? If there's a difference, what then?
As you probably well know, the Electric field due to an infinite sheet is σ/(2ε(naught)). But this gives something about 2.43 times smaller than what was given. Does this proportion have anything to do with how the field distributes itself?
The proportion is not particularly relevant. What is relevant is that the observed field strength is not entirely accounted for by the sheet's field.
If the field due to the sheet of charge doesn't account for the net field observed, what does that tell you about the contribution from the "other charged objects" that were mentioned? What happens if your observer moves (a very small distance indeed) from the right to the left of the sheet?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
