Finding the electric field at 3 points due to 2 identical charges.
To find the electric field magnitude at three points (A, B, and C) due to two identical positive charges, the calculations involve using the formula E = (1/4πε)(q/r^2). Point A has the largest distance from both charges, resulting in the smallest electric field strength, while point B experiences cancellation of fields from both charges, leading to zero electric field strength. Point C, being closer to one charge, will have a stronger electric field than point A but less than point B. The discussion emphasizes the importance of considering both the magnitude and direction of the electric fields from each charge. Ultimately, the ranking of electric field strengths from weakest to strongest is A, B, and then C.
get_physical
3 points (a,b and c) and two identical positive charges. How do you find MAGNITUDE of the electric field at the 3 points? I just need to rank them, don't need numbers.
all points are on the x-axis:
A (x=0); charge +Q(x=1); B (x=3); c(x=4); charge+Q(x=5)
(Picture attached in the 3rd post)
E= (1/4pie) (q/r^2)
I just focused on the r^2 since everything in the formula is the same.
for point A: 1^2+ 5^2 = 26
Point B: 2^2+2^2 = 8
Point C: 1^2 + 3+2 = 10
so would B then have the greatest strength while A has the least?
E= (1/4pie) (q/r^2)
r2 is in the denominator. You need to add or subtract 1/12 and 1/52, 1/22 and 1/22, etc.
Also you haven't taken into account the direction of the E field from each charge.
Picture attached
Yes, r^2 is the denominator, that's why the smallest r^2 will have the strongest field. Can you please explain what you mean I need to add or subtract?
In that case, would there be no electric field strength at B? since the directions are opposite, so they cancel each other out?
Yes.
As for using 1/r, not r2:
1/1+1/52 = 25/25 + 1/25 = 26/25
1/22 + 1/22 = 1/4 + 1/4 = 1/2   (Yes, I know these should be subtracted, but this is just to illustrate the point.)​
SammyS said:
Yes.
In this case, after doing the calculations, would a have the smallest electric field strength since it is -26/25, and then after that would be B with 0 and finally, C?
would you just assume the left is negative while if arrows pointing to the right is positive?
Thanks
What do you get for electric field at point C ?
Look at the problem statement. It asks about the "MAGNITUDE of the electric field". (That capitalization was in your original post.)
As with number lines, it's fairly standard to consider a vector pointing to the right to be positive, and left is negative.
Oh ! thank you so much I finally got it. thank you for your patience. appreciated!
