Finding the horizontal distance that the cork flew
  • Thread starter Thread starter jheld
    Horizontal
The discussion revolves around calculating the horizontal distance a cork travels after popping from a champagne bottle resting on a frictionless table. Given that the bottle slides backward 22 cm in 0.42 seconds and has a mass 500 times that of the cork, participants emphasize the importance of conservation of momentum to find the cork's initial velocity. The initial velocity of the bottle is calculated as -52.381 cm/s, but there is uncertainty about deriving the cork's initial velocity. By applying conservation principles, the cork's velocity can be determined, allowing for the final distance calculation. This approach will lead to a solution for the cork's landing position on the table.
jheld
A 14cm diameter champagne bottle rests on its side on top of a frictionless table. Suddenly, the cork pops and the bottle slides backward for a distance of 22 cm in .42 s. If the mass of the bottle is 500 times the mass of the cork, find the distance from the original position the cork will land on the table.
14 cm diameter
bottle final distance is 22 cm
time is .42 seconds
mass of bottle is 500 times mass of cork
p = mv
Sf = Si + Vi*t + (1/2)(a)(t^2)
Vf^2 = Vi^2 + 2a*S
Vf = Vi + a*t
I got a little lost.
I figured:
-22 cm = 0 +Vi*t
Vi = -52.381 cm/s, Vi for champagne bottle.
I'm having problems getting one more variable (the Vi for the cork). I'm not sure how to derive it.
Once I get the Vi for the cork, I should be able to solve the problem.
Hi jheld,
14 cm diameter
time is .42 seconds
p = mv
Vf^2 = Vi^2 + 2a*S
Vf = Vi + a*t
I figured:
-22 cm = 0 +Vi*t
What is conserved in the process of the cork shooting out of the bottle? If you write a conservation equation for that quantity you should be able to find the velocity of the cork right after it leaves the bottle.
