Finding the initial Y velocity, angle, etc from a kicked football
To determine the initial Y velocity, angle, and other parameters of a kicked football, the initial X velocity was calculated as 11.23 m/s using the formula Vx = Vi(t). The discussion highlights the need to find the average velocity (Vavg), initial Y velocity (Vy), and the angle of projection. Key formulas for vertical and horizontal motion are provided, emphasizing that the Y component experiences acceleration due to gravity (-9.8 m/s²), while the X component remains constant. Understanding the relationship between these variables is crucial for solving the problem effectively. The conversation underscores the importance of applying kinematic equations to derive the necessary values.
Soupy21
The problem is this, you need to determine: The initial Y velocity, initial X velocity, angle reference to the ground, maximum height of the ball, and length of the field goal you should be able to kick.
I kicked the ball 27 yards, and it was in the air for 2.2 seconds. It was easy to find the initial X velocity, just do Vx = Vi (t) which came out to 11.23 m/s. But how am i supposed to find the Vavg, and or Vy (initial Y velocity) and the angle, when i don't have either of those?
The formulas available are:
dx = Vix (t)
dy = Viy (t) + 1/2 (ay) (t[squared])
Vfy[squared] = Viy[squared] + 2(ay)(dy)
Vxi = Vi (Cos[angle])
Vyi = Vi (Sin[angle])
Including other basic ones as well, but those are the main ones. How do i go about doing this problem? I think once i find the initial Y velocity and angle, i can figure out the rest of the problem. But this is tricky...
Thanks in advance, and if anything needs clarified, or was confusing, just ask. Any help at all is very appreciated.
What does 'a' equal in your 'dy' equation? Which is the acceleration of all 'falling' objecs? Which component of the velocity is constant? The x or the y component? (Hint: in which direction is there no acceleration?)
A = accelteration. So Ay is acceleration in the Y direction, which is -9.8 for gravity.
The X acceleration is constant, because we haven't factored in air resistance. (even though its there)
