Finding the max range of a jump on the moon using kinematics
The problem involves calculating the maximum horizontal jump distance on the Moon using kinematics, based on a known jump distance on Earth. The context includes the gravitational differences between the two celestial bodies.
  • Participants discuss finding the initial jump speed and applying it to the Moon's gravitational acceleration to determine the jump distance. There are questions about the relationship between gravity and jump range.
Some participants have provided calculations and insights into the relationship between jump distance and gravitational acceleration. There is an ongoing exploration of the implications of these calculations without a clear consensus on the final approach.
Participants are working under the assumption that the jump angle remains constant at 45 degrees and are considering the effects of different gravitational forces on jump distance.
garcia1
A person can jump a maximum horizontal
distance (by using a 45 ◦
projectile angle) of
4 m on Earth.
The acceleration of gravity is 9.8 m/s
What would be his maximum range on the
Moon, where the free-fall acceleration is g
6 ?
Answer in units of m.
Kinematics equations
All I can think to do is set kinematics equations for the x and y-axis equal to each other by another variable, such as time. This is as far as I can figure out with this problem.
hi garcia1! :smile:
(have a degree: ° and try using the X2 icon just above the Reply box :wink:)
from the first part, find the speed at which this person can jump
then use that speed with the Moon's g to find how far he will jump on the Moon …
what do you get? :smile:
24.0304m/s, by using the fact that vf = 0, and then solving for VoY and getting 6.26m/s. I then plugged this into:
Y = Vy^2 - VoY^2 / (2*-9.81m/s^2 / 6) = 12.01518
Multiplying by two because I used Vf = 0 at the top of the jump, I got 24.0304m. It was right!
:biggrin: Woohoo! :biggrin:
ok, now have you noticed that the range is inversely proportional to the gravity (24/4 = 6)?
can you prove that, and so avoid all the tedious arithmetic? :wink:
